NEW {OFFICIAL KitKat 4.4 720p/1080p} CR11S/CS968 2MP/5MP ROM Builds Now Available
    They are KitKat 4.4 720p/1080p {Official} CR11S/CS968 ROM Builds Now Available {Beyond XBMC v3.4/v3.5} Ready. I'm still in the process of testing the new KitKat ROM builds their will be a custom 4.4 KitKat ROM Builds In The works ... You can also get more info HERE https://plus.google.com/communities/...artnerid=gplp0 ..
    You get the new CR11S/CS968 2MP/5MP KitKit 4.4 ROMs HERE http://en.cloudnetgo.com/CR11S2M.htm ...
    Mirror #1 Get the 2MP Version HERE http://www.sendspace.com/file/efqwd5
    Mirror #2 Get the 5MP Version HERE http://www.sendspace.com/file/xmdal1
    *1080p Set up Settings:
    Using a terminal emulator type: (use at your own risk after setting your TV to 1920 x 1080 x 60) ...
    Code:
    su
    wm size 1920x1080
    wm density 240
    Reboot your Android TV box ...!
    A Full Customized Android TV KitKat 4.4 CR11S/CS968 Home Screen
    How To Access Wallpapers, Widgets And Settings Via Android TV KK
    4.4 ROM Builds? Just Left Click On Your Mouse/Mouse Keypad The Above Photo Screen Will Auto Appear ...
    NEW Android TV KitKat 4.4 CR11S/CS968 Has Been Rooted ... Some People Still Don't Believe This ...
    ROOTING INSTRUCTIONS:
    A lot of you are having problems with how to SYNC your Android TV box with your PC ... Another easy way to SYNC your Android TV and PC is via "Moborobo" first before running the "Kingo RooT app ... Doing it this way, you will know already, if your Android TV and PC are SYNC before you run the Kingo Root App ...
    Please Note: Before doing any of the above, the correct drivers must be installed on your PC ... See post # 1 for the drivers package download, if needed ...
    You can get the "Moborobo" app HERE http://www.moborobo.com/products/ ... Please read the easy, instructions first ...
    ROOT INSTURCTIONS:
    Please use the simple easy, easy, easy root instructions here using the "Kingo Root" method found HERE
    http://www.kingoapp.com/android-root.htm ... Please install the "Kingo Root" app to your computer, before going any further ...
    If you need drivers for your Windows PC, you can get them out of the ROOT package found HERE http://www.mediafire.com/download/55...CR11s_root.zip ...
    1.\ First make sure ALL DRIVERS ARE INSTALLED On Your PC, on your Android TV box {CR11S/CS968} go to Settings> Developer options> in the upper right corner turn "ON" USB debugging, click/tap "OK" and check mark the block "USB debugging", click/tap "OK" ...
    2.\ Next connect your Android TV box to your computer via USB ... Go to Settings again and go to USB, check mark the block "Connect to PC", you should hear a sound from your computer ...
    3.\ Now run/open the "Kingo Root" App on your computer, once the "Kingo Root" app has sync to your Android TV box, just tap on "Root Again" ... Be patient this may take a few minutes, your Android TV box will auto reboot, you Android TV box is now rooted ...
    *Mods Please Do Not Lock This Thread, so I can make added Changes if needed
    Can anyone please test if overscan settings get saved on reboot. They won't on the KitKat build from csq, so i'm wondering if they will save on this ROM.
    Sent from my Nexus 5 using Tapatalk
      has anyone been able to download? I stall at 1.1mb If you could kindly post somewhere with decent access that would be helpful thanks, Ynot
        New Mirrors
        New mirrors are now in post #1 ...!
          Ok, I just installed this rom, it is NOT 1080p, only 720p, also it is not rooted. Seems very stable though.
            Root Instructions And ROOT Tools Package
            How to root The 4.4 CR11S/CS968 NO PASSWORD REQURIED (EASY ROOT)
            The CS968/CR11S Quad Core Google Android TV BOX Can Be Rooted Via The Instructions Below ....
            June 22, 2013 Thanks To Eric Android TV Stick/ TV BOX
            *NO PASSWORD REQUIRED
            Make sure USB Debugging is enabled on your 4.4 CS968/CR11S ROM Build (Settings -> Developer Options)
            Connect your CR11S to a Windows PC via the mini USB port. (now only support rooted via Windows PC, no linux or Mac)
            Your PC should detect a new device, and try to install the driver. You can download the driver HERE http://www.mediafire.com/download/55...CR11s_root.zip ... The RK3188_ROOT.rar unzip password is GEEKBUYING.COM in capital letters (Not Needed) ... Drivers are included ...!
            After having installed the driver, download HERE RK3188_ROOT.rar , and extract the files ...
            Click “ TPSparkyRoot.bat” and follow the instructions. After 2 reboot, your device should be rooted. If not rooted do a third reboot that should do it ....
              Goole Play Services Certified
              NEW Android TV CR11S/CS968 4.4 KitKat 720p ROM Build (Google Play Services Certified) ... Please post your new discoveries about our new CR11S/CS968 4.4 KitKat ROM build, thanks in advance ...
                I still can't get this device to root. If you have yours rooted let me know so I can download it. Also, is your new kitkat rom 1080p
                thanks
                  thanks
                  I still need to fix the correct binary for the CR11S/CS968 devices, work in progress ...
                    Now you have me confused. I downloaded your rom listed here and installed it. It does not have root. Did you root your box AFTER you posted the link? I was not able to get my box rooted using your directions. Also, what do you mean by correcting the binaries?
                    thanks
                      thanks
                      The ROMs are not rooted, you have to root the ROMs, after you install the ROM on your device, using the method described above ... I'm talking about the correct su binary ..!
                        I feel really dumb, but I have tried a dozen times to get this program to work using your instructions. I am not sure what I am doing wrong. I made sure I had the correct drivers for my windows 7 machine. But when I use the TPSparkyRoot.bat file, it still does not find my device. I have tried both a regular usb port and otg port on this device. I have tried depressing the reset button and even holding it, I hear the computer make a beep, but the TPSparkyRoot.bat still can not find the device. I have no problems at all rooting 4.2 roms.
                        thanks again for your help.
                          Go Settings> Developer options> USB debugging must be check marked, only one time ... In Settings go to USB> check mark Connect to PC ... This must be done after each time you device boots all the way up ... You will do this three times, before your device is rooted ...!
                            I know I am getting on your nerves by now. Any way, here is what I do.
                            Go Settings> Developer options> USB debugging must be check marked, only one time Done That
                            ... In Settings go to USB> check mark Connect to PC Done That
                            Disconnected android box from tv ( power, ethernet cable, and HDMI cord. Took box to my desk, connected male usb connector to usb port on computer and other end of male usb cable to otg usb port on android box. Depressed little reset button on android box, heard the computer make a connection sound. Clicked on the TPSparkyRoot.bat file. Dos window opened, hit the space bar, in the dos box, it said "device not found"......
                            ... This must be done after each time you device boots all the way up ... You will do this three times, before your device is rooted ...! This part I do not understand????
                            Again, thanks for your help, and I know I am driving you crazy....
                              I checked this rom and it works fine, except of it is not a real 1080p ROM, looks really sharp, but no full hd. Can someone confirm my result.
                              JD
