I have test the new KitKat 4.4 ROM build to the "T", yet I have not found any advantage over the current 4.2 ROM builds ... IMHO, I believe you are better off to keep your 4.2 ROM build on your device ... Don't even waste your time installing the KitKat 4.4 ROM on your device, simply because their is no advantage, bottom line ...!
NEW {OFFICIAL KitKat 4.4 720p/1080p} CR11S/CS968 2MP/5MP ROM Builds Now Available
KitKat 4.4 ROM Build Offers No Advantage
Originally posted by Tech1 View PostI have test the new KitKat 4.4 ROM build to the "T", yet I have not found any advantage over the current 4.2 ROM builds ... IMHO, I believe you are better off to keep your 4.2 ROM build on your device ... Don't even waste your time installing the KitKat 4.4 ROM on your device, simply because their is no advantage, bottom line ...!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI don't know why, but my TV01 seems more stable with the CS968 roms. Something about the CR11/s that my box doesn't like.
1080p videos playing in youtube seems to be very smooth. (I use Ethernet).
CR11s version blackouts way too often.
D33 Kitkat kernels (beta) were not stable at all. Tried many of them and like somebody reported, the LED was bright solid blue with CSQ rom but was very dim blue with D33 kernels. Had to plug out/plug in multiple times to get it to boot similar to my experience with CX 919 II.
Is the CSQ version a true 1080p ROM?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Thanks for replying! Does your CS968 also have blackouts?
Mine does with almost every ROM I have tried though with the stock/Tech1's ROM, the TV keeps showing the "Hdmi input N" every now and then but no blackouts.
Would this be my board issue or ROM issue?Tronsmart Orion R68 Meta
Not sure what you mean.
Black outs while booting: I saw this never with stock ROM either 4.22/4.42, but with custom ROM/kernel
After booting complete: I assume, it has either something to do with the power supply. Over otg the ROMs seem always a bit hungry for a stronger power supply - so blackouts could cause to this point.
With the ac power supply it should be stable with stock ROM.
Basicly I don't think it is a hardware problem, but maybe the cs968 have a very unique board design off standards.
JDfense --->I8160
Originally posted by ghanashyaml View PostThanks for replying! Does your CS968 also have blackouts?
BeYond XBMC v3.5 Coming Soon
Originally posted by JDfense View PostOne question for Tech1: Why do we have the announcement for a new beyond XBMC in the headline of the new kitkat stock?
JDfense ----> Nexus 7 ~ 2013
Originally posted by pincer View PostI have cs968 htc018 2013 11 v3 board with mtk bluetooth (6622 or something) and wifi (59??), I installed custom rom and stock rom. I even install from cloudnetgo (nice). I dont have any issue you mention, all went well.., ofcourse, when i install AP6210 version I dont have wifi nor bluetooth connection. My tips is, beside what chip of network u have, dont forget about the camera resolution (2mp or 5mp) i only install the 2mp firmwares.
Thanks for the tip. Yes, I too have the 2MP camera and I always install only the 2MP versions. But still the issue.
Maybe some solder is loose which worsens when it becomes a bit warm?Tronsmart Orion R68 Meta
Originally posted by JDfense View PostNot sure what you mean.
Originally posted by JDfense View PostWith the ac power supply it should be stable with stock ROM.
For the board snapshot, you can check my previous post to compare with any other boards you have seen? My board seems very similar to others I have seen in these forums.
Maybe the HDMI solder is loose somewhere which becomes worse when the board gets warm?Tronsmart Orion R68 Meta
There are currently 2411 users online. 0 members and 2411 guests.
