I also checked the display resolution by entering
wm size,
the system responded with
physical mode is 1280x720
override mode is 1920x1080
Although AnTuTu or CPU-Z uses the overrided display resolution, the screencapture function no longer works after using wm size override. Do you have a similar problem or just me?
What is the difference between a real 1080p or emulated resolution?
hkp168
