NEW {OFFICIAL KitKat 4.4 720p/1080p} CR11S/CS968 2MP/5MP ROM Builds Now Available
may I know how to root it by Kingo root? I follow instruction but my PC keep saying not connected. I can connect the cs968 as drive, but kingo root just said not connected. when I check my laptop, I found that the device cs968m not installed properly, is that the problem? And is that correct if I connected through otg(or need connect usb port?)
Originally posted by ghanashyaml View PostLooks like my specific v4 has some strange issue which only 1 or 2 kernels are able to fix. Whats the link for
htc_t018_public_mtk_csq_20140419? I could not find it.
I have tried multiple kernels and ROMs and the search will continue until I find the one which fixes my main blackout issue. I did not try all HDMI settings with all the kernels/ROMs I tried.
Right now I am using htc_t018_public_ap6210_csq_20140411 but am wanting a true 1080p. Have tried the terminal emulator but su gives access denied error even though the ROM shows rooted. Maybe Kingo app will fix it.
Difference between true 1080p and emlulated 1080p? This has been asked before but I did not see anyone answer this question.
a: whether you have partially rooted or the root checker need to be update, been that situation too.To root 4.4 is different from 4.2 method, kingoapp will fix it for sure.
in your current rom htc_t018_public_ap6210_csq_20140411, did the wifi and bluetooth works?
Originally posted by andylcm View Postmay I know how to root it by Kingo root? I follow instruction but my PC keep saying not connected. I can connect the cs968 as drive, but kingo root just said not connected. when I check my laptop, I found that the device cs968m not installed properly, is that the problem? And is that correct if I connected through otg(or need connect usb port?)
Sync Your Android TV And PC Via "Moborobo" First
A lot of you are having problems with how to SYNC your Android TV box with your PC ... Another easy way to SYNC your Android TV and PC is via "Moborobo" first before running the "Kingo RooT app ... Doing it this way, you will know already, if your Android TV and PC are SYNC before you run the Kingo Root App ...
Please Note: Before doing any of the above, the correct drivers must be installed on your PC ... See post # 1 for the drivers package download, if needed ...
You can get the "Moborobo" app HERE http://www.moborobo.com/products/ ... Please read the easy, instructions first ...
Originally posted by pincer View Posta: I made a thread for kitkat rom 4.4 (Stock Rom) here
We all are learingYes, Kingo app worked and I was able to get into su
In that ROM, I am just using LAN port. Wifi/BT will not work since mine is a MTK chip. LAN works much better than Wifi, so not much issue there for me.Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Beyond XBMC V3.4 Rules {Hands Down With The Option To Use The MXPlayer For Local Video, Movies Playback}
NEW Channels Addons zip Download Location Below, Please Read The Simple Easy Instructions First ...
If You desire ALL the top addon channels via the Beyond XBMC v3.4, then you will need the NEW XBMC7.9 Updated Channels.zip files ..
You will need to unzip the "XBMC7.9 Updated Channels.zip" on your PC and install "XBMC7.9 Updated Channels folder" to your Android TV box internal SD Card "Download Folder" ...
There you can easy access each addon channel zip files to install them by just tap/click on each addon channel zip file, one at a time to install the channels addon zip file to your Beyond XBMC V3.4 ..
*You want to install the "repository Superrepo.org.all addon zip file" FIRST, located in the "XBMC7.9 Updated Channels folder" immediately after the Beyond XBMC v3.4 open during the first installation by going to SYSTEM> Addonbrower (tab below)> "Install from zip file"> External storage> Download (folder)...
There in the Download folder you will see the "XBMC7.9 Updated Channels folder", tap/click on it and install each addon channel zip one at a time ... Each time you will auto go back to "Install from zip file", just repeat the install process for each addon channel zip file ..
You can get the "XBMC7.9 Updated Channels.zip" from HERE IN THE TOP POST https://plus.google.com/communities/...artnerid=gplp0 ...
You can get the latest Beyond XBMC v3.4 HERE
http://www.freaktab.com/showthread.php?10139-Beyond-XBMC-%28Beta-3%29 ...
The MXPlayer set up option via the Beyond XBMC v3.4, go HERE
https://plus.google.com/communities/...artnerid=gplp0 and read about how to set up the MXPlayer correctly to help with tuff video files playback, it's a new series, just released as promised ... Also get the FREE$$$ MPEG-2 plugin ...!
You can now get the latest ShowBox and VideoMix Movies Apps HERE https://plus.google.com/communities/...artnerid=gplp0 ...Last edited by Tech1; 01 May 2014, 13:36.
Originally posted by bjaurus View PostI tried all settings in the "Sound Manager" one by one... does't work, and so many times i upgraded and downgraded my device. JB works, KK nohow
Also give me complete details on just what you are trying to do via HDMI, example are you trying to play the XBMC via HDMI ...?
Using Your Android TV Box As A ChromeCast Dongle
THIS IS GOOGLE ANDROID TV:
Android TV 4.2/4.3/4.4 Quad Core Boxes Can Be Use As A ChromeCast Dongle
{Using Apps Like Plex, ALLCast And BubbleUPnP For Casting All Types Of Media Files To Your Giant Screen Android TV}...
Here again is a short Picture series showing the advantage of owning a Android TV 4.2/4.3/4.4 Quad Core TV Box and using your Android TV box as a ChromeCast Like Dongle via your Android smartphone or tablet ...
Notice in the photo above, they are several Renderers device {Cast To Devices} two Android TV boxes, local BubbleUpnP, Intergalaxtic {A ChromeCast Dongle} and to my Beyond XBMC v3.4 ... Yes, you can even cast to your XBMC {Proper Easy Set Up Required} ...
It a well know fact, the default DLNA/UPnP media player, that's found on the CR11S, CS968 and Minix Neo X7 is light years ahead of any XBMC media player, that's on the Android market today, that includes the MXPlayer too ...
You want to know why the default DLNA/UPnP media player found on these boxes are so superior, because it can handle just about ALL known media codecs with power, giving you video playback without frame loss or skipping ...
World Cup Soccer App
World Cup Soccer "{ESPN FC APP}" On The World Stage {Bring Your "A" Game} HOT! HOT! HOT!
The "{ESPN FC}" App Download Is Below For Advance 4K READY Android TV Quad Core 4.2/4.3/4.4 Boxes
You can get the "{ESPN FC}" App HERE
GOOGLE ANDROID/NEXUS TV XBMC CHROMECAST
{Side Loading Is Required}
There are currently 3014 users online. 2 members and 3012 guests.
