Tronsmart S89 Standard Finless 1.2 ROM
Originally posted by wolfe View Post
Originally posted by Brinis View PostThink something went wrong at me. My box is just showing the robot where it says a finless bob rom it's been like that for 20 min now. Is there something I can do about that ?
It should not take that long. Seems like you're in a boot loop.
I just followed this nail biting thread here : http://www.freaktab.com/showthread.p...-ve-bricked-it
Are you sure you flashed the correct rom - Vega standard vs vega elite?
Originally posted by Brinis View PostI got it to where it says
reboot system now
apply update from adb
apply update from ext
apply update from cache
wipe data/factory reset
wipe cache partition
and I don't know what to do
I've never installed just using the remote, I use a usb mouse, I don't know if you can do it without a mouse plugged in.
Remember though only flash a rom that is for your device or you'll end up like me :-)
I did that I did not workI'm just trying to do it with the standard rom and right now it's rebooting and the mbox just came up now I'll just have to se if the rest will come also.
and now there is a welcome
but I still need to root it so I can use xbmc on it
So will have to try one more time with the finless now
Originally posted by Brinis View PostFor some reason I can't root it. It doing the same again after I try to root it.
Originally posted by rad View PostThere's a sticky for just the rooting, have you tried that?
http://www.freaktab.com/showthread.p...oot-ZIP-update
I love you.well I did. But thank you. Kind of feel blind I been looking at that but don't know why I did not use. We'll all is fine now. And I learned some things
Originally posted by eduardosmelo View PostI'm very concerned about temperature freezing because here in Brazil it is 95ºF, usually. My unit hasn't arrived yet.
Worse case you will need to drill some breather holes but I suspect this will not be necessary.
see http://www.freaktab.com/showthread.p...x-%28square%29
(The beelink m8 is exactly same as tronsmart vega s89)
Originally posted by Lokie View PostShould be fine... The unit runs very cool & has good thermal design (for chinese product).
There are currently 1916 users online. 2 members and 1914 guests.
