Tronsmart S89 Standard Finless 1.2 ROM
Originally posted by noderat View PostGotham at minimum. For passthrough you need the one that came with the ROM. Finless has it in another thread.
Sent from my mobile device. Please excuse any typos.S**t I allready instaled the 12.2,can u Pls add the link to download it, .........never mind I found it
Use 5ghz for your WiFi, even if you only have 2 bars if your getting better speeds then I don't see the problem. 5GHz is like that for me as well, I get 1-2 bars and incredible speeds but if I do 2.4GHz I get full bars and typically only 11mbps - 25mbps. Also 2.4GHz slows down if you have 802.11b clients on the network.
Okay so it seems I must have had some configuration issue when I first tried Gotham and passthrough. It appears that Gotham nightly 20140410 does passthrough (max 5.1, 7.1 isn't working and no DD-TrueHD either)
If you can't get Gotham nightly to do passthrough do a factory reset (wipe /data) and try again. Whatever testing they did to my box before they shipped it to me caused it to not work in nightlies. Works great now.
Re: NEW - Tronsmart S89 Standard Finless 1.2 ROM
Originally posted by mini__me View PostDo you still have the 0.5 second offset configured with the nightly or is that no longer required?
Originally posted by mini__me View PostYou are doing a stirling job of testing Sir!! Thank you!!
Originally posted by mikiemon View PostI tried to use my F10 Pro remote with this unit, as the included remote blows. Audio defaults to USB sound, I can hear it but sound and video stutter badly. Is there any way to manually select the HDMI as the sound output or disable the USB sound?
Sent from my Nexus 5 using Tapatalk
Originally posted by mikiemon View PostI've never heard of that app, but it does sound promising. I'll try it when I get home from work. Thanks
Mike
You can disable USB microphone by editing /system/etc/audio_policy.conf
Ok got 4x beelink 16G devices today. 5.5 days DHL deliver half way around the world - amazing deal
http://www.aliexpress.com/item/10pc-...752324384.html.
First priority for me is to solve the 0.5s delay in audio for XBMC.
Like the stuff that is going on here! Thanks for the work guys!
Regarding sound delay - what about this I found? :
Going to give it a go...
No delay in latest xbmc nightly
There are currently 3892 users online. 0 members and 3892 guests.
