Pipo M8 Pro RileyROM 2.2 KitKat
Hi y'all,
I've just registered to post this. First of all thanks for the highly optimised firmware i just flashed to my m8 pro. It does indeed works as it should be working , it's finally flying...
If you are wondering why your benchmark scores are lower -although the tab is blazing fast in responses through menus wich is from this kk version- and overall lower performance is because the cpu freq is capped at 1400mhz. It does not go all the way up to max 1.6 altough every software will show the theoretical range from lowest to 1.6, u get it.
Maybe we can have a fix and even some overclocking versions ?
Ohhhhh and btw it's really a new tablet, fabulous performance, thanks riley for the support!
I think we had some custom kernels for the JB ROM's, but the kernel patching guys haven't shown any love for the M8 Pro since I put out this KK ROM.
Perhaps a little nudging is in order. There's a thread for that in the main Pipo section:
Randy
Originally posted by rrileypm View PostI think we had some custom kernels for the JB ROM's, but the kernel patching guys haven't shown any love for the M8 Pro since I put out this KK ROM.
http://www.freaktab.com/showthread.p...or-Pipo-models
What else can be improved upon?Cube T9; Pipo M8 Pro (on life support); LG gPad
BamaPanda, you are mostly right. If it ain't broke...don't fix it pretty much applies here. I go by performance during use. I've never put much stock in benchmarks.Randy
The deep sleep feature has been one of the biggest headaches to manage. Is your tablet equipped with 3g?Randy
Originally posted by grfxguy View PostFlashed this KK ROM to M8PRO13090238 with no problem following your most excellent directions. Tab is much faster and boots much quicker. I have experienced two instances of tablet not waking up from deep sleep even though Daydream is turned off.
Press the button one time, And don' t rush it. See if that helps.Cube T9; Pipo M8 Pro (on life support); LG gPad
The tablet turns itself off.
I installed the ROM last week and the improvement has been abysmal. But yesterday, the tablet started to restart itself. At any time after starting, (sometimes on startup, others five or ten minutes) the screen freezes with a double image (as 3D images red blue) and after a few seconds shuts off. Any idea?.
I don't know if it is related to the change of ROM, but I am very worried. Do you know if anyone has had this problem?. During the week I've had the ROM I had no problem.
There are currently 2234 users online. 1 members and 2233 guests.
