Pipo M8 Pro RileyROM 2.2 KitKat
You can check the early posts on the M9 Max thread to see how that developed.Randy
vonino primus qs
can someone tell me if:
vonino primus qs here http://www.vonino.ro/primus_qs is compatible with m8 pipo pro without 3G? ??
I saw others who have asked this tablet, but nobody said if the flash this rom from m8 pipo pro
now has android 4.2.2, but I want kitkat for performance
expect an answer from anyone [email protected]
thank you,expect any advice
It appears that some later versions of the M8 Pro are compatible with this KK ROM. Early versions aren't. While I made this ROM I've never been able to flash it on mine without bricking.
My tablet only has 1 NAND chip...while the newer versions had 2...so that may be the difference. We figured out that this was the case on early M9 Max tablets...preventing them from flashing the KK bootloader.
So, just let me say...flash at your own risk. Maybe go ahead and remove the back cover and look at the NAND chip(s). If there are 2 of them, you should be OK.Randy
I need a favor from an M8 Pro user who is able to run this KitKat ROM. Not all of the M8 Pro's are able to run it, because of the earlier versions having compatibility issues (explained in the above post).
From the KitKat version, we need a dmesg log to view the components in an attempt to make a whole ROM from scratch using the SDK provided to us by Pipo and Rockchip.
This needs to be done as soon after boot as possible.
From a terminal app run the following commands:
su (confirm the Superuser prompt)
dmesg >/sdcard/m8pro_kk_dmesg.txt
Browse to your root folder of your sd card (internal) and share us the m8pro_kk_dmesg.txt file that was produced. The best way to do it is to upload to Google Drive and share to "anyone with the link" and copy and paste the privided link in this thread...or PM it to me.
Thanks in advance!!!!!!!!Randy
Originally posted by rrileypm View PostI need a favor from an M8 Pro user who is able to run this KitKat ROM. Not all of the M8 Pro's are able to run it, because of the earlier versions having compatibility issues (explained in the above post).
RilyRom 2.2.4.4.2 KOT49H eng root 20140225.141712 test keys
...can I be of help?Cube T9; Pipo M8 Pro (on life support); LG gPad
Yes, that's the ROM I need the dmesg log for. Just follow the above instructions. You can PM me the link...and cc d33...he's the one who needs it.Randy
Thanks...I believe we are good now.Randy
vonino primus qs compatible with pipo M8 pro
happy new year , 2015 !
for those who tablet vonino primus qs here http://www.vonino.ro/primus_qs is compatible with Pipo M8 pro without 3G
I flash rom android next 4.4.4_gen2_2.15_01.11.2014.img
go flawlessly, then I installed launcher pipo, Xposed, greenify and control performance
after several optimizations we obtained in AnTuTu benchmark over 25,000 points, although vonino has only 1 g RAM (shows me that would 2g ram)
I have not found any bugs, no resets, go games, movies online and about 5-6 hours battery you use depends on
the only problem I noticed is pretty weak wifi signal, can anyone suggest me a patch to improve this
I hope that does not bother anyone with my post, but I have seen other users vonino Searching tablet versions rom this forum
I thank you for these ROMs and will continue to follow
excuse my poor EnglishLast edited by calyn; 04 January 2015, 09:14.
Happy new year
Hello,
I flash my tablet with the ROM 2.2.0
Everything went fine.
My tablet's version is
M8PRON13070879
Yesterday i tried to flash with the 2.2.1
I erase IDB and continue with the flash process.
During the process my brother remove the wire
Now.... Nothing.
The tablet doesn't respond, and pc don't see it at all.
I've try the sequence "Press ESC..reset...Power, release Reset..ESC...
still nothing
any suggestion?
Thank you for your time.
EDIT:
I put to the charger and the tablet turn on.(with a icon that shows there is a problem)
i connect it with the pc while it's still on and i use the same sequence (esc,reset.Power), and now works fine.
Continue with the flash and finish it with no problems.
Thank you for your great work!!!
The good news is that we do have developers working on KK for the M9 Max with 1 NAND chip...but results are very slow to materialize.
If, through their testing, we find the secret to getting KK to work...maybe we can get it working on the M8 Pro.
I also have an older M8 Pro that will require this "special" configuration....so I hope we make some progress on it soon.Randy
Unfortunately this version of KK has some major compromises. Hopefully we can fix some of those things with a new release one of these days.Randy
There are currently 2629 users online. 0 members and 2629 guests.
