Yet another version of of the 10b G3 ICS ROM. This one is a user dump from J_Weidner over on Arctablet.com. Some 10b G3 tablets distributed in Germany, etc seem to have different screen hardware. If you flashed other 10b G3 ICS ROMs and your screen did not work, then this ROM will probably fix that.
Below is the link for both stock ROMs. I am calling this other version the German version as this is where these tabs with different screens are showing up.
Ok folks....
FIRST a special thanks to FreakTab user AlleyTrotter for dumping this ROM!
Everyone should thank him for getting this dump out while others (cough... you know who you are) held onto it for whatever reason! I made a post asking for a dump and Alley stepped up and in a few hours had a dump.
Alley, YOU DA MAN!
.gif)
You now all have a REAL stock ROM for the Arnova 10b G3. And let me just say it is the latest ROM from Arnova we know of to date! Yes there is another 10b G3 ROM out there but after a lot of analyzing and research by me, this for sure is a newer release than what is out there right now.
1) The kernel has a newer build date
2) The system and resource files all are newer too.
So as far as I know, this is the latest available. If Arnova would properly version thier releases and document changes we would all not be guessing like we are now. Totaly SHAME on Arnova for this approach!
Anyway so let me explain what this ROM is:
1) Alley dumped his ROM but I asked ONLY for backup.img. Backup.img is in fact the stock ROM in a package. So no matter WHAT he installed or did to his tablet backup.img is not touched in any way! It is stock!
2) I took backup.img apart and did NOTHING TO IT other than to make it into it's parts and a flashable ROM kit. You cannot flash backup.img directly so at a minimum it must be made into it's parts to flash it. That is all that has been done to it. Unlike others out there, I did not try to repackage the ROM into an update.img as this can have reprocussions TRUST ME. It's best to have a ROM just like how it would be flashed by the manufacturer!
3) On this ROM unlike other RK29 ROMs, by default kernel.img is built in boot.img. So THERE IS NO kernel.img to flash. I have modified the flash tool to uncheck kernel.img as needed. This is so you do not get errors using the RKAndroid flash tool. DO NOT try to check kernel in the tool or you will get an error!!!!!
OK so thats about it. PLEASE..... read the readme.txt file in the ROM kit for more information.
So with the mumbo jumbo over with
ROM -> Arnova 10b G3 - ICS - Stock ROM (125 megs)
ROM -> Arnova 10b G3 - ICS - Stock ROM German Version (125 megs)
Enjoy,
P.S. for the 10 G2 people out there... do not bother. This ROM will not work on the 10 G2. I do not know if it will work on the 10b G2 but I highly doubt it! It seems there are more hardware changes on the 10b G3 vs 10 G2 that the kernel will not even boot! I will look into this farther but it is not a good sign about getting ICS on the 10 G2
