Looks like I've bricked it.
Originally posted by rad View PostIt was formatted to ext fat that was the only choice, I got a 4Gb today so I'll try that tonight.
Originally posted by Finless View PostIt has to be FAT32. Not many android devices support ext FAT!
The recoery.img I am using is 9190Kb and dated 28/02/2008
The wps file is usb刷机工具说明.wps 92Kb in size and dated 26/02/2014
Is that what you have Bob?
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Posthttp://www.freaktab.com/showthread.p...OM-on-your-S89
1. 'SDcard making tool' (burnBootCard.rar) to create the SD
2. u-boot.bin and usb刷机工具说明.wps from AMLogic_tools.rar to SD
3. recovery.img from zip to SD
4. boot from SD (A/V toothpick) => USB port came up and the AML flash tool would see it
and SD is FAT32 and 4. didn't work?
I'm going to try another sd card now.
Maybe you don't really need the recovery at the sd (because also no factory_update_param.aml exist), the device only boot with the u-boot at the SD card and the u-boot needs the wps to support usb (but which one?) to connect to PC...
(or rename it to 'uImage_recovery'???)
What you can also try is to replace the u-boot at PC at the directory with the 'BootcardMaker.exe' with the one at the root at amlogic_tools.rar, because I'm not really sure (remember) but I think, the 'BootcardMaker.exe' do something special with the SD card and this is, that it places something in front of the partition ... (and Bob wrothe nothing about screenoutput at hdmi, only about connection to PC)...
RK3288 Devices
Originally posted by no_spam_for_me View PostMaybe you don't really need the recovery at the sd (because also no factory_update_param.aml exist), the device only boot with the u-boot at the SD card and the u-boot needs the wps to support usb (but which one?) to connect to PC...
http://www.freaktab.com/showthread.p...l=1#post101209
Just trying it without the recovery.img and still nothing.
I wonder if Eric could get the correct files for the SD card from tronsmart instead of me just trying everything
Recovery doesn't need to be there but it has a known good kernel in it so once you get the flash tool past init disk, then recovery kicks in and you can update from sdcard. However once past init disk the next thing (I forget the name) gets stuck flashing and once you get past that, you can use the flash tool 100%. I just figured it would be easier to use sd update.zip after getting past init disk.
So the bottom line is
SDcard maker and use the correct u-boot.bin
Then put u-boot.bin and the wps file on sdcard and this is where I at least got the PC and flash tool to see it.
I am not sure why yours is not working?
FYI, when you run the SDcard maker tool, make sure you run it as administrator!
Oh and also remember to keep holding the reset button in until windows bongs! This does take quite a bit of time (like 40 seconds or so).
One more thing!!!
BTW, when I bricked..... I had a solid red LED all the time. It never turned blue until after flashing init disk with the tool.
If you are not getting any LED then that is your problem!
Check your power connection! My cord or plug is flakey and if I wiggle it I can loose power! I think my cord has a bad wire in it right at the plug. If I flex it around it will stop working. If I wiggle it, it will power up again.
Do you have a volt meter and can check the power cord at the plug?
Originally posted by Finless View PostOh and also remember to keep holding the reset button in until windows bongs! This does take quite a bit of time (like 40 seconds or so).
I'm going to try a different sd card then call it a night I think.
It's not looking good like, I'll see if I can get anything off of Eric that's official for de bricking.
For those how are interesting in... a little "forensic"
Beyond Compare 3.3.5
The 'amlogic_tools\u-boot.bin' and the 'burnBootCard\u-boot.bin' are totally different.
The 'amlogic_tools\burnBootCard\u-boot.bin' and the 'burnBootCard\u-boot.bin' are identical.
notepad++
I don't know, if the u-boot.bin is compressed or not, but, because of the 'amlogic_tools\usb刷机工具说明.wps', I try to find '.wps' or 'usb'.
No '.wps' at 'amlogic_tools\u-boot.bin' or 'amlogic_tools\burnBootCard\u-boot.bin'.
'usb' only at 'amlogic_tools\u-boot.bin'.
=> I think not really helpfull.
SD Card
1.) At WinXP CClean to wipe SD Card and at Linux (VirtualBox) 'sudo dd if=/dev/zero of=/dev/sdb bs=1 count=7885565952' to kill all at the SD Card (also MBR/MPT)
2.) At WinXP format with 'HP USB Disk Storage Format Tool 2.2.3' with FAT32 (No Quick Format)
Code:total: 7.885.565.952 byte available: 7.885.561.856 byte each allocation unit: 4.096 byte allocation units: 1.925.187 available allocation units: 1.925.186
=> image for future compare '8GB_SD_FAT32.img'
WinHex ('8GB_SD_FAT32.img')
Code:000000000 | 33 C0 8E D0 BC 00 7C FB 50 07 50 1F FC BE 1B 7C | 3ÀŽÐ¼ : 000007E00 | EB 58 90 4D 53 44 4F 53 35 2E 30 00 02 08 26 00 | ëXMSDOS5.0
Right mouse button at device
Code:total: 7.864.434.688 byte available: 7.864.430.592 byte used: 4.096 byte
=> image for future compare '8GB_SD_BCM.img'
WinHEX ('8GB_SD_BCM.img')
Code:000000000 | 06 00 00 EA 60 F1 9F E5 60 F1 9F E5 60 F1 9F E5 | : 000FB0400 | EB 58 90 4D 53 44 4F 53 35 2E 30 00 02 08 26 00 | ëXMSDOS5.0
compare '8GB_SD_BCM.img' with 'u-boot.bin'
000000000 -> 000054FF6 => 348151 Byte
Code:Search for differences 1. D:\8GB_SD_BCM.img: 7.901.020.160 bytes 2. D:\Downloads\Android\HW\Amlogic S802\burnBootCard\u-boot.bin: 348.151 bytes Offsets: hexadec. 1BE: 80 00 1C1: 02 01 1C4: FF 7F 1C5: BF E0 1C6: 82 C1 1C7: 7D 3E 1CA: 3E E0 1CB: D6 A9 1CC: EA 75 9 difference(s) found.
RK3288 Devices
notepad++
SD Card
Bob, if you read this any chance you could use the HDDRawcopy util above to copy your SD card you used to an image file and upload it for me somewhere, don't do it if you are at all unsure of how to use it though, I don't want you busting anything on my behalf.
Cheers guys,
RAD
There are currently 4036 users online. 1 members and 4035 guests.
