Looks like I've bricked it.
Originally posted by alkalinia View Posti have a same problem,but my pc recognize my vega s89,like amlogic,but usb burning tool not,i try different ways,nothiing,where iam wrong???,why burning tool dont recognize my vega s89???
RK3288 Devices
- Overview BOX (LINK !)
Find usb刷机工具说明.wps
Originally posted by rad View PostAre you allowed to swear on these boards ?? Bingo, it's flashing. (flashed now)
Thanks guys,
The sequence of what to do if your machine bricks is as follows.
Create the SD card using the bootcardmaker.exe util which is contained in the amlogic_tools.rar which can be downloaded from the tronsmart.eu website.
When creating your bootable sd card using bootcardmaker.exe and the u-boot.bin that is 352Kb in sixe (thanks Bob), once it's formatted copy that file and the usb刷机工具说明.wps file onto the sdcard.
Now you need to open up your vega (only do this if you are not getting any joy with any other method, mine was unresponsive to anything), and short out the 2 pins in the link below.
https://drive.google.com/file/d/0B9B...it?usp=sharing
I couldn't get mine out of the base and to be honest you don't really need to, I shorted them with a small screwdriver.
now...
1) Unplug and plug back in power. No LED should be on. (also have your SD card inserted)
2) Short the pins and hold them shorted.
3) Press the reset button and hold it.
4) Power on the box using the power button.
5) Continue to hold reset and pins shorted until Windows bongs,
You can now flash your rom using the USB flashing tool and .img file of your choice, I used the original firmware.
Do a normal attempt at flashing the first time, it will fail at 3% or something like that, next repeat above and do a full erase which should get you to about 5%, You will need to restart the program each time.
The next time you do the flash untick the box that says "Erase bootloader" it will then flash further to about 6%, this is the sweet spot because at this point you no longer need to short out the pins, you can remove the SD card and you can restart and flash as normal and it works.
I hope this helps someone.
Thank you very much guys for all your help with this, especially finless Bob.
A very happy RAD.
PS. Bob, on your next ROM can you make the robot smile, my little girl prefers it when he's happy. lol
Originally posted by Tiago View PostHi, i had this issue trying to change the firmeware from the s89 to M8 dummy xD, I am looking for this file usb刷机工具说明.wps to complete this steps and solve this brick... were e can find this file !?
=> USB Burning Tool v2.0.0.140306 Alpha x86
RK3288 Devices
Thanks guys,
now...
A very happy RAD.
I have the same problem, but my pc does not recognize the vega. I don't know what I'm doing wrong.
I create the microSD card using burnbootcard (pick a card, I select "To partition and format" - YES, I choose u-boot.bin 352kB, I click" Make ", I agree to formatting the card and at the end I'm successful, then copies on the card u-boot .bin (352 kB) and usb 刷 机 工具 说明 .wps and put the card into the vega)
- Then plug in Tronsmart Vega S89 elite microUSB cable for pc
- Connect an HDMI to TV
- Unplug and plug back in power. No LED should be on.
- Short the pins and hold them shorted
- Push and hold the reset
- Push the power button and hold
- Then I wait and wait and nothing ... computer with win 7 64bit nor with windows 8 64 bit does not recognize any usb device, there is no reaction.
Can anyone help me?
Originally posted by panho View PostI have the same problem, but my pc does not recognize the vega. I don't know what I'm doing wrong.
Can anyone help me?
I tried on different microUSB cable does not work on any. How long do I have to keep closed pins and pressed the reset and power button? For me, the effect is that for the first 4 - 5 seconds the red LED, and then changes to blue. PC did not recognize the Vega.
TV shows that detected a 1080p signal but nothing is displayed.
If I remember correctly, Bob wrote something about more than 30 sec. before windows recognize it...RK3288 Devices
Originally posted by kelvcast View PostDo I have to short the pins? Windows recognizes the devices but the flash tool does not see it
JustMeBugs are Sons of Glitches!
JustMe
Hi guys.
I bricked my S89 too. I'm trying to follow the guyde by rad & finless but I can't create the SD recovery.
I'm using the botcardmaker tool with the 352kb u-boot.bin. After formatting the tool says "success" but the SD Card is always empty.
I'm using Windows 8 X64. Is the tool incompatible with that OS? I cant get the USB-Burning tool to install either. Do I have to use a VM? What do you guys think?
Sincerely
BonzenPaule
Sincerely
BonzenPaule
After you make the card, then copy over the other needed files (with windows) which you WILL see when they are copied over.
Originally posted by Finless View PostAfter you format and make the card it WILL be empty to Windows. What that tool does is write a boot sector to the beginning of the sdcard which is used by AMLogic boot process.
Anyways... Thanks for the guide and fast support!
I guess I got a Problem with my windows drivers. When I try to install the USB_Burning_Tool_v2.0.0.140306_Alpha_x86 to my Windows 8 x64 I get the following error message at the end:
It basically says that it failed to install lib-usb32 WorldCcup_Device (01/18/2012 1.2.6.0)
After that I tried to start the usb burning tool but I always get this error message:
I always use "Run as an Administrator" to install the burning tool and to run it.
Windows recognizes that an M8-Chip is connected to the computer but it says that the driver is missing.
When I use the formated SD with both files and press the reset button and short the 2 pins and press the power button on the S89 I get the Windows "Connect" sound after 3-4 seconds.
Did somebody encounter something similar and is able to help me?
There are currently 2532 users online. 1 members and 2531 guests.
