CS968 MTK T018 NEW {No Chinese Apps Version Available} Custom 4.4 Live TV, Netflix, AC3 DTS Multi-Media Super ROM {NO XBMC}
Originally posted by pejochto View Post
Help
I'm very new to android (noob), I was following your instructions but the usb wasn't connecting to the kingo app but moboro had it verified and shown as connected. I went and I tried resetting the CS968 box but I keep getting the android logo with the box inside the android turning.
I tried another method using rkbatchtool but I couldn't get the usb(otg) to connect properly to the pc. I get this error on in the device manager :
unknown usb device (device descriptor request failed)
What do I do ? how do i fix it?
Originally posted by newbie1020 View PostI'm very new to android (noob), I was following your instructions but the usb wasn't connecting to the kingo app but moboro had it verified and shown as connected. I went and I tried resetting the CS968 box but I keep getting the android logo with the box inside the android turning.
also make sure you have usb debugging on and connect to PC checked off in your settings. If you are using windows 8.1 you may have an issue with the device being recognized by your PC. I did research somewhere and someone posted a fix somewhere but I couldn't figure it out so I just used an older laptop I had with windows 7 and it worked like a charm.
Hopefully you can figure it out because this rom is awesome .
my thanks to tech1Last edited by tbca; 15 May 2014, 13:28.
See The Difference
My Custom 4.4 KitKat ROM Build On The Bottom Top Photo Is On A 1080p TV Screen ... My Custom 4.4 KitKat ROM Build In Lower Photo With Icons Is On A 720p TV ... This Is How I Test All My Custom ROM Builds {I believe Even Stevie Wonder Can See The Difference}
Originally posted by Tech1 View PostMy Custom 4.4 KitKat ROM Build On The Bottom Top Photo Is On A 1080p TV Screen ... My Custom 4.4 KitKat ROM Build In Lower Photo With Icons Is On A 720p TV ... This Is How I Test All My Custom ROM Builds {I believe Even Stevie Wonder Can See The Difference}
What tools do you use? Do you use android kitchen? Do you do it in linux (virtualized or not)? What are some of the tweaks you do. Any info and help would be greatly appreciated and very helpful.
Originally posted by servo386 View PostTech1, would you mind giving me a little insight into your process of making custom roms? I'd like to try my hand at it but am having a hard time getting up to date consice info about it.
Originally posted by Tech1 View PostThey are several ROM kitchen on this forum, explaining things you need to know ... Now to be honest with you, it's not a over night thing, it's something that takes time to learn ... I started out with Windows mobile 5 devices and making cab files app back in the day ... When Android came out I learned all I could about Android devices and the Android OS ... Like I said, it takes time to learn this stuff ...!
hotspot
Ben bu ROM yükledim, ama hotspot çalışmıyor.
WiFi hotspot çalışmıyor ve benim telefon çalışıyor ama göremiyorum.
I installed the 4.4 ROM but none hotspot in the third one did not work and naturally ehomecent program does not see the phone.
This problem KitKat 4.4 ROMs chronic problem?
WiFi HotSpot Works Like A Charm Via KitKat 4.4 ROM Build
Originally posted by nazmi28 View PostBen bu ROM yükledim, ama hotspot çalışmıyor.
Did You Know Your Android TV Quad Core 4.2/4.3/4.4 Box Can Be Use As A WiFi HotSpot (Notice In The Photo Below My Mr.Sammy Note 3 Is Connected To "AndroidAP"
My Android TV Quad Core 4.4 Box Is Connected Via "AndroidAP" {See The Top Photo} Via WiFi HotSpot
Some Say This Doesn't Work, But It Works Like A Charm For Me ...!
Sir, the problem is not in the 4.4 KitKat ROM build, the problem is in your home network or your mobile device ... I feel you guy, we got to blame it on something, when it doesn't work for us ...(lol)Last edited by Tech1; 17 May 2014, 23:46.
Great Rom, but a couple of issues
HI Tech;
This has to be the best ROM that iv'e seen for my Mtk839 Cozy unit. I do have a couple of issues though. I hope you can offer some insight to.
1) When video set to 1080 in android settings screen will flicker on and off throughout most applications.
If I set to 720 it's does it alot less and lowest settings doesn't do it at all. Any idea why my Android box would do this?
2) I really would like to use eHomeMediaCenter as a default player in xbmc. Can you tell me how to set this up? I use both beyond xbmc and gotham beta 1. I really like Gotham but I really want to change the video player to something different.
I did a bit of research and found that I can modify the player file, but I can only find examples for mx player.
Thank You so much for such a great rom and I hope you can assist with my questions..
RJLast edited by bobsj2000; 18 May 2014, 07:22.
One more question about rooting
I am new to this, so please understand.
I followed instructions to a tee trying to kingo root. I can't seem to get the drivers to install properly
on the PC. I have windows 8.1 - Is there any way in particular that I should try to install them with this version of windows?
Thank YOu,
RJ
Thank YOu,
RJ
RJ
Concerning 1080p video playback, If you are using the HDMI cables that came with your CR11S/CS968 that's most likely the cause of your video flicker, I had the same problem ... The HDMI that came with your Android TV box, throw them in trash can, no good at all for high speed video transmission ...
Go MonoPrice and get the ferrite cores HDMI High speed cable {Not Called 1.4 HDMI Cables Anymore} is what you want with ALL your Internet TV devices, plus these cables have a Ethernet feature too ... Get them HERE http://www.monoprice.com/Product?c_i...seq=1&format=2 for $3.00 each ...
There are currently 2039 users online. 3 members and 2036 guests.
