I've noticed that my device now starts on its own since loading this ROM. It can be totally powered down and then hours later I find its powered on? I've removed all the bloat ware - any views? No other apps have been loaded on the also?
CS968 MTK T018 NEW {No Chinese Apps Version Available} Custom 4.4 Live TV, Netflix, AC3 DTS Multi-Media Super ROM {NO XBMC}
Originally posted by nguy View PostI've noticed that my device now starts on its own since loading this ROM. It can be totally powered down and then hours later I find its powered on? I've removed all the bloat ware - any views? No other apps have been loaded on the also?
Originally posted by Tech1 View PostYou are the cause of you own problem, their is no bloat in this ROM build .... As they say, if it's not broke, then don't fix it ...
Be In The Android TV KNOW, Knowledge Is Power
If you were a member of the GOOGLE ANDROID/NEXUS TV XBMC CHROMECAST message board, you would be in the KNOW about the Google/ESPN coming good news, and all Android TV news pertaining to your Android TV box ... You can get FREE$$$ Android TV apps, located in the left column under "Android TV Apps", apps you may not even know about, that will enhanced you and your family's Android TV experience ...
How it works, all post updates are auto sent to your Android smartphones/tablets, keeping you in the KNOW, knowledge is power ... Also their is a link in the right column, giving you direct access back to this website, join today ...
Originally posted by Tech1 View PostIf you have a lot of Chinese bloat apps let me know fast and I will start upload a new ROM build very fast without Chinese bloat apps {That Big Chinese Pay-Per-View App}...
If everybody is happy, I will let the few Chinese apps stay ...! Maybe the Chinese people wants this custom ROM build also, enjoy ...!Originally posted by Tech1 View PostGood luck removing your Chinese apps, I would not do it that way, enjoy ...
Originally posted by nguy View PostI saw your post above, did as you asked but then didn't want to bother you as you were working on another ROM. How would you remove the Chinese bloat apps?
CS968 MTK LIVE TV {NEW 20140504 T018 Custom 4.4KK ROM Available} Netflix, AC3 DTS READY, Multi-Media Super ROM
I have the custom ROM in this version and the same happens to me, so I dont think this is depending on either Chinese apps or Tech1:s modification.
If you do a new ROM on this build could you please remove the Nexus start screen that flashed up when you start the box?
And I will give a try.
Pejochto via TapatalkCR11S AP6210 Chipset
CS968 MTK Chipset MT5981 - MT6622
HTC-T018-V04
Originally posted by nguy View PostI removed the Chinese apps in the ROM as you mentioned in an early post using App Manager. These would not have caused the device to turn on automatically, would it?
*New {NO CHINESE APPS VERSION} MTK T018 Custom ROM Build 20140504 {Install XBMC Of Your Choice}
*New {NO CHINESE APPS VERSION} 20140504 {HTC T018 MTK Public ROM Build}
Download HERE A FAST WORKING LINK https://plus.google.com/communities/...artnerid=gplp0 ...!
{Just Scroll Down To Post Number 0708, The Downloads Are There}Last edited by Tech1; 20 May 2014, 22:01.
Is this the new ROM without Chinese Apps and Beoynd XMBC under the headline below?
There is three download links in that post, just want to be sure...
New Firmware 20140504 {HTC T018 MTK Public ROM Build}
Originally posted by Tech1 View Post*New {NO CHINESE APPS VERSION} 20140504 {HTC T018 MTK Public ROM Build}
{Just Scroll Down To Post Number 0708, The Downloads Are There}CR11S AP6210 Chipset
HTC-T018-V04
Sorry my fault, i scrolled down to far and went in to the old 708 post, I did find it now.
Did you modify this ROM the same way with video resolution as you did with the others, or have you just removed Chines Apps and Beyond XMBC?
Originally posted by pejochto View PostIs this the new ROM without Chinese Apps and Beoynd XMBC under the headline below?
HTC-T018-V04
Originally posted by pejochto View PostI have the custom ROM in this version and the same happens to me, so I dont think this is depending on either Chinese apps or Tech1:s modification.
{Just Scroll Down To Post Number 0708, The Downloads Are There}Originally posted by pejochto View PostSorry my fault, i scrolled down to far and went in to the old 708 post, I did find it now.
There are currently 5203 users online. 3 members and 5200 guests.
