Tronsmart S89 Finless 1.4 ROM
    Originally posted by Methanoid View Post
    Now I know the answer to BOTH questions is in this thread and could easily be found by reading it
    I read alla the 7 pages but i'm lost, can you quote The answers or write it? Thanks
      You are joking of course? Post 121 (at the top of this page) has the info you seek. If you did read 7 pages you clearly didnt look very carefully!
        Originally posted by Ulrbru View Post
        Hi pollicin123
        do you mean that I have to use the option number two on the guide?
        Intendi che devo usare l'opzione 2 sulla guida?
        thanks
        Bruno
        Faccio prima in italiano: non devi usare per me la ROM 1.2 ma la 1.4 così da aggiornare per bene tutto.
        Quindi scarica il file .zip della 1.4 dal post principale del thread e poi segui le istruzioni all'interno (io consiglio il punto 1 anche se non ho ancora provato)
        English version: you do not need me to use the ROM 1.2 but the 1.4 update so good for everything.
        Then download the file. 1.4 zip from the post of the main thread and then follow the instructions inside (I recommend 1 point although I have not tried it yet)
          thanks for the reply, doyou know if there is a way to fix the problems with the apples f10 pro? thank you
            Grazie policin123. Ho trovato la soluzione. Dovevo inserire la password che a suo tempo avevo messo e me ne ero dimenticato. Ora l'ho tolta. Grazie ancora comunque è buona giornata/Bruno
            English: I solved the problem. I forgot to I had a password. I just prompt it and now it works. I removed it now.
            thanks
            Bruno
              Will this rom work with the tronsmart S89 h
                i dont think so the s89H uses a differnt chipset, i saw them talking about it somewhere on this forum
                  Any news about mele f10 pro and this ROM? have Anyone else try ti use The ROM with f10 pro?
                  Thx
                    Hey Finless, is there a way to set the spoof as a Note 3 or S5 to get HD content from the various android streaming apps (i.e. TNT, ESPN, ABC)? It's NBA Finals time!!
                      I believe Nexus 10 will do that?
                      For others you mention I would need their build.prop file so I know what to set.
                      Bottom line if your rooted you can edit it yourself. The parameters you change to spoof something is:
                      ro.product.model=GT-I9300
                      ro.product.brand=samsung
                      ro.product.name=m0xx
                      ro.product.device=m0
                      ro.product.board=smdk4x12
                      ro.product.cpu.abi=armeabi-v7a
                      ro.product.cpu.abi2=armeabi
                      ro.product.manufacturer=Samsung
                      ro.board.platform=meson8
                      Just replace those with another devices info. The above is a GT-i9300 by Samsung. This was the stock info for the S89/S82 as an example
                      ro.product.model=VEGA S89
                      ro.product.brand=MBX
                      ro.product.name=k200
                      ro.product.device=k200
                      ro.product.board=k200
                      ro.product.manufacturer=MBX
                      Be careful changing
                      ro.board.platform=
                      It may cause a boot loop depending on what you put there.
                        Be careful changing
                        ro.board.platform=
                        I am rooted and using your 1.4 currently. I do not know how to change the spoofing but if you have a small write up, i could perform it myself.
                        EDIT: I have a mac with no immediate access to a PC
                          You do it from Android.
                          Install ES file explorer
                          run it
                          turn on root explorer
                          click root explorer again and set system as RW
                          go to /system/build.prop
                          edit it
                          save it
                          reboot.
                            tronsmart vega s89 vs minix x8
                            Ok here goes. I currently have a minix x5 with finless 1.3 rom. I have now had this box for over a year working just fine. Now I want to get another box. With the tronsmart priced well and the reviews so far it looks ok. Just wondering if I recieve one do I need to update firmwares before flashing finless 1.4 rom. Otherwise this sounds like a well priced animal compared to what I'm seeing for the x8. Maybe the x8 has something in store for us but that is to be determined? Before I decide I will wait for reviews for that box. These are the two I am considering.
                              run it
                              edit it
                              save it
                              reboot.
                              Got it
                              so the new build.prop file will be
                              ro.product.model=Nexus 10
                              ro.product.brand=google
                              ro.product.name=mantaray
                              ro.product.device=manta
                              ro.product.board=manta
                                Got it
                                Yep in fact my 1.5 ROM will be using that. here is mine
                                BOb
