Tronsmart S89 Finless 1.4 ROM
Originally posted by manati45 View Post
Re: NEW - Tronsmart S89 Finless 1.4 ROM
Originally posted by manati45 View PostI am still running Finless 1.4 rom but changed to latest xbmc nightly. I tested again today and got three different antutu scores within a few mnutes apart: 31590, 31446, and 31666 with a temperature reading of 86F. I then watched a movie from mashup and tested again and got 31841 and still 86F. I tested with 1080 movie clips and they played smoothly with no a/v sync issues with XBMC nightly and connected with ethernet. I am sticking with Finless rom 1.4 till 1.5 comes out.
☆sent from an xNote powered sm-n900t w/tapatalk☆
You are right, my mistake. But mine does not get hot, it is just slightly warm on the bottom and and even less warm on the top. I have raised it so it sits a bit higher to dissipate better the heat plus my house is air conditioned and the temperature is always 80F or below. I was also thinking that maybe you can remove the top and drill some small holes so the heat would escape, just an idea.
Originally posted by manati45 View PostYou are right, my mistake. But mine does not get hot, it is just slightly warm on the bottom and and even less warm on the top. I have raised it so it sits a bit higher to dissipate better the heat plus my house is air conditioned and the temperature is always 80F or below. I was also thinking that maybe you can remove the top and drill some small holes so the heat would escape, just an idea.
My box doesn't get hot.
But the soc throttles down and leaves me locked at the aforementioned frequencies. I and a couple others noticed my heat temp on trickster, which was vety high.. but I have since found out that trickster is reading this soc correctly. So I have no idea what my issue is. Im looking for an app now that displays cpu temp.
I check/touch the box when all cores are locked at 1200 also and the temp doesn't feel any hotter that it was in then beginning. Idk
help please
I'm new at this forum, can you help me with my tronsmart Vega elite s89?
I want to install this rom but i have any question:- did all cores work of the TV box with this rom ?
- How are the benchmark?
- I have to install the patch of the wifi?
System Config.
CPU: Amlogic S802 Quad-Core 2.0G (Cortex-A9)
GPU: Mali-450
4K*2K : Support
RAMDR3 2G
ROM: Nand flash 8G
Expand Memory: 1*Micro SD Card Slot, support max 64G
Antenna: Built-in wifi antenna
Media
Video format: Support multiple video decoding ; 4K*2K H.264 ,1080P
Picture format: JPEG/ BMP/ GIF/ PNG/TIF
Communication
Ethernet : 10/100M LAN
WIFI:AP6330,Support 802.11 a/b/g/n,2.5G/5G WIFI
Bluetooth: Bluetooth v4.0
Sensor/Motor
IR Sensor: 1*IR
Indicator
Power LED:1* white LED
Button & Ports
Button: 1*Power Button(physical button), control power on and off; 1*Update Button(via one pin hole)
USB2.0:2* Standard USB; 1*Micro USB with OTG
DC-in: 1*DC in Jack
HDMI:1* standard A HDMI 1.4b out, 4K*2K
SPDIF:1*S/SPDIF out
RJ45:1*RJ45
TF Card Slot:1*TF card slot
AV:1*AV port
Power management
Adapter:5V 3A
Software Config.
OS:Google Android 4.4, support OTG function
Language : Multi-Language
Keyboard :Qwerty keyboard
Features
Miracast/DLNA: Support
UI: Android Original UI
I've read through most of this thread and havent found clear answers:
1) Can I use this Rom for the S82? I thought I saw some analysis including opening the boxes and comparing that said this is the same as the Tronsmart, even coming from same factory?
2) I’d rather avoid XBMC 14 alpha as it would likely not play well with 3 XBMC players all on 13.0 release. Does 13.0 include AML hardware acceleration or do I need a special version of XBMC 13?
3) I’ve noticed that RK3188 devices often have crappy slow NAND flash which makes them crawl to a stop if you are downloading several Play store updates making them unusable until updates have finished. Does this exhibit that problem?
Originally posted by Methanoid View PostI've read through most of this thread and havent found clear answers:
Sent from my SGH-I747M using Tapatalk
I went from 100k4 then went to this rom 101k4 after that went to finless 1.4 .. im waiting for 102k4 should be released soon.. as a zip update... I have downloaded apps from the appstore however I did not do many at a time so I cannot help on that.. make sure to download the wifi patch or u wont have internet ... so I went back from 1.4 to this kne 101k4 ..
Originally posted by Ulrbru View PostHi I installed the custom 1.2 on my s89. Now it doesn't work. When I start my s89 I can only see the desktop and a message that say you can only ring emergency number. Can you help me with that?
Bruno
I don't no if I am on the right thread for this question. How can open a new thread. I am new at the forum so I need a little help.
thanks
Bruno
Originally posted by Ulrbru View PostI don't no if I am on the right thread for this question. How can open a new thread. I am new at the forum so I need a little help.
thanks
Bruno
Bruno prova ad usare l'ultima versione e flashare quella tramite la guida che trovi nel readme del file .zip
do you mean that I have to use the option number two on the guide?
Intendi che devo usare l'opzione 2 sulla guida?
thanks
Bruno
There are currently 1949 users online. 1 members and 1948 guests.
