Tronsmart S89 Finless 1.4 ROM
Originally posted by londonshore View PostDamm I have the s82 and I downloaded urs finless lol how can I get that... I followed ur directions fml im lost I have 1.4 with ur elite wifi patch
Sent from my SGH-I747M using Tapatalk
antutu 31960 on s89 standard on 101 ROM rooted.
Antutu shows good scores on 101k4. Have not installed finless ROM. Went from 100k4 to 101k4 and then installed root through finless method.
While the test was running, I had killed all other processes. What is worrisome though is that my brand new, Wonderful nexus 5 scored 21000
Posted this because some people were wondering if this is an issue with 101k4.
Sai
Re: NEW - Tronsmart S89 Finless 1.4 ROM
Originally posted by sai021 View PostAntutu shows good scores on 101k4. Have not installed finless ROM. Went from 100k4 to 101k4 and then installed root through finless method.
Sai
Sent from my Nexus 5 using Tapatalk
Copying to usb hub attached hard drive
I noticed that on both the 1014K and the Finless 1014K firmware I can not copy from a usb thumb drive attached to a usb hub to an external sata harddrive attached to the same usb hub using ES explorer. I used the same combo on the minix neox7 and it did not have such an issue. Is there any thing that could be causing this to happen. Thanks in advance.
Originally posted by benny638 View PostI noticed that on both the 1014K and the Finless 1014K firmware I can not copy from a usb thumb drive attached to a usb hub to an external sata harddrive attached to the same usb hub using ES explorer. I used the same combo on the minix neox7 and it did not have such an issue. Is there any thing that could be causing this to happen. Thanks in advance.
Come to think of it, you have to pay microsoft royalties if you want to include the linux based software that gives you write access to an NTFS volume, so that is probably why they don't
need help
so i have the 1.4 finless installed how can i get rid of that and go back to the 101k4 ? did the antutu test 30850 weird was 28000 last time ... oh well i cant uninstall 1.4 any help would be appreciatedLast edited by londonshore; 16 May 2014, 23:37.
If you chase Antutu scores to DEATH.... You will go nuts!
You will find as long as it does not vary more than about 2000 points... your chasing a DEMON!
Scores different than 10K, well then go try... but do not chase a "nat's ass" down a rat hole!
Originally posted by stb2xxx View Postyes, i have this problem
Originally posted by Ice_Coffee View PostI haven't tried it myself but I remember hearing on here that these firmwares only have read access on an NTFS volume, no write access. The fix was to use Paragon from the market.
Come to think of it, you have to pay microsoft royalties if you want to include the linux based software that gives you write access to an NTFS volume, so that is probably why they don'tRK3288 Devices
- Overview BOX (LINK !)
There are currently 2503 users online. 1 members and 2502 guests.
