Sent from my SGH-I747M using Tapatalk
Tronsmart S89 Finless 1.4 ROM
Re: NEW - Tronsmart S89 Finless 1.4 ROM
Originally posted by londonshore View PostNo it doesnt and batfink32 im using win 8 this could explain my troubles thanks I will stick with finless for now ... thanks
Bobs ROM is just the stock ROM with his tweaks that make it better added. Your not missing anything that stock ROM doesn't have.
Sent from my Nexus 5 using Tapatalk
Sleep problem
Originally posted by gojo View PostI am on S89 elite and Finless 1.4 rom. When I put S89 on standby LED going from red to blue then again to red. It is happening all the time when box is on standby. Anyone with same behaviour?
Kitkat issue
I know or have read that kitkat increased the overall security, but I was wondering if anyone is having this problem. Using ES file explorer (or any other file explorer as I tired about 10 of them) if I try to send a short cut to the desktop or home screen nothing happens. The only way I get it to work is to download a shortcut maker from google play. Im just trying to add a folder shortcut to a folder on an externally attached hardrive. Using ES file explorer worked on my minix neo x7 using finless and quickshot roms. Overall this ROM is ROCK SOLID not crashes or reboots.
Originally posted by benny638 View PostI am having the same problem. I even tried a apk called sleep.apk and it would working meaning the light would stay red and I could bring the device out of sleep using my tronsmart air mouse but if i let it sleep for a long time say over night and try to bring it out of sleep the light turns blue, but there is no picture. It appears the box is confused and doesn't know its not suppose to be sleeping.
odd video problem
i had finless 1.3 and my videos played properly but since updating to 1.4 i can not get my videos to scale properly to fill the screen. ive tried multiple players and changed every setting possible. ive also used a wide variety of file types but to no avail.
also im not sure if its been discussed but doe anyone know why external hdd mounts as read only? it wont even allow me to change it read write.
Originally posted by Batfink32 View PostThere was another thread on this. I think its to do with the kernel CPU frequency going too low during deep sleep and not having enough power to wake the box up. You have to keep the box in "screen on" mode all the time. To do this, go into Settings>About Tablet and press "build number " 7 times. Then reboot. After reboot go into Settings >Developer Options and there is an option for keep screen on always. If you check this option then the box will always stay awake and never go into deep sleep mode.
this is what I do and I've never had a problem with re-waking with it enabled
☆sent from an xNote powered sm-n900t w/tapatalk☆
Originally posted by Nowandlayda View Post102k4 .img up on geekbuying blog http://blog.geekbuying.com/index.php...ifi-all-fixed/
finlessbob 1.4.
Thank you so much for your hard work on this ROM. It is a solid ROM & it works allot better than the stock ROM did, however, I have noticed that with the power off app you get with this ROM dose not work. When I go to power off my tronsmart vaga standard it just restarts it again. It never powered the box off it just restarts the box. Other than that its a grate ROM. Thanks again. PS. Have you got an app that dose the same thing. Thank you. PS. I forgot to say, I have a f10 pro air mouse and when I plug it in, the video gose all choppy on me, & iv no sound coming through at all. When I unplug the f10 pro, it works fine. Now I'm back to using my Logitech keyboard. Pitty really,because I like my f10 pro.Last edited by bigall123; 19 May 2014, 10:25.
There are currently 2502 users online. 1 members and 2501 guests.
