Gesendet von meinem AN9G2I mit Tapatalk 2
Arnova 9G2 Finless Bob's "GingerComb" Custom ROM Version 2.1 CWM Release
OK folks.... I hope this is the final release!
Have at it:
ROM -> Arnova 9 G2 - "GingerComb" Finless 2.1 CWM (205 megs)
let´s get ready to Rumble...Xperia Arc @ 1,2 GHz - 8GB Class 10 - MooDeD ICS 90.2 - ThunderBolt Kernel
Arnova 9 G2 - 16GB Class 6 - Custom-ICS 1.2 by Finless Bob
500MB more Space on Dropbox for you and me http://db.tt/5t167vjX
For me CWM without any problems. I have installed the reboot thing whit injector, gave SU permission, it installs a srcipt and the i can reboot in recovery... Sorry for bad englishPlugged my wireless mouse to usb, works
next edit... Templerun with Chainfire 3d ok, youtube videos in hd ok... thanks for this rom, for me it seems final
Everything seems to be working perfect, can boot into CWM via the reboot app. Only thing is when making a backup (to either internal sd or external) it backs up everything fine until it gets to "Backing up data".
Then I get this message at the end of the process: "Error while making a backup image of /data!"
Tried several times, even flashed the image a few times to make sure it was done right.
I also get this weird bug where either the root seems to disappear (until reset of tab) or superuser force quits continuously until I uninstall/reinstall its update.
Any ideas/tips guys? =/
Did you flash the loader? That is required for sure on this ROM! CWM needs 2.14 loader.
Erase IDB?
Seems your having some odd problem. Make sure your SDcard is NOT corrupted which is very common. See this post here about that:
http://www.freaktab.com/showthread.p...Understand-WHY!
All I can say is start over as for sure something did not go right.
It's working fine.
But there are some problems with the german translation. The Settings-Button is "Ein-stellungen" instead of "Einstellungen". If I press the menu-key, I get two Launcher-buttons (one "Einstellungen", one "Launcher.Launcher") AND I really miss my Volume-softkeys....
Some Menus are mixed, german & english.
Will you also debloat the ICS Rom for the 9g2, maybe that could be as fast as this one.
n14
Hmmm.... well the translation are from the Cube... But I might be able to fix "some" of that maybe.... I will look into it.
As for making ICS faster. It's not the debloat I do not think. I can do a debloat for that but it's the basic fact that 512mb RAM just does not perform well on ICS. If you search google, you will see lag and other issues plague ICS when you don't have 1meg of ram. So I am not sure debloat will help much.
I will look into the translation files. I know for basic stuff how I might fix that but for things that are in the framework or APKs, I wont be able to. Sorry.
As for the soft volume buttons. Sorry Honeycomb got rid of those as least on this ROM. Maybe I can see if Miklaus can add them back at a later date.
Originally posted by Finless View PostDid you flash the loader? That is required for sure on this ROM! CWM needs 2.14 loader.
Erase IDB?
Hey Bob, I tried starting over a few times and still no dice, checked the sd card and the internal memory, both were fine. So out of randomness I left the SD out when backing up and oddly enough it worked.
Guess I'll just have to leave it out when backing up and restoring XD
Amazing ROM and from others feedback on it, sounds like its perfect =]
I have read that some SD cards can have a problem with CWM. There is not much I can do about that. It's called a RW race condition and has to do with low level code.
What is the rating e.g. "class" of your SD card?
You will see on the card a number with a C around it. If you do not have that then your card is sub-standard and probably cannot handle the write speeds CWM is trying to do. If you have a class 6 or above, I understand from studies that it should work.
So I have to say... awesome ROM... WiFi works, CWM works, I installed my fav game Radiant Defense and with Chainfire 3d it also works.... Sadly it is not supported by Chrome, i am using Dolphin but its not working out between the two of us -- Anyone have a suggestion to a better browser?
the only thing that bugs me is the launcher, it can't compare to apex... which only works for ICS i think, thus i will probably use ADW, or try another suggestionor can one change things like the notification appearing on the status bar below and the spacing on the side of the icons?
other than that... perfection!!!!!!
thanks finless!!!!!
There are currently 1624 users online. 2 members and 1622 guests.
