thanks
Arnova 9G2 Finless Bob's "GingerComb" Custom ROM Version 2.1 CWM Release
Strange
Have you put it into recovery when your tab it totally switched off.
Try switching tab off . Don't plug tablet into computer yet. Try putting it into recovery now. When screen goes black than plug it into computer.
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
What does it show up in device manager when your tab is plugged in?
There are loads of things to try the first been the cable as in try a different one. If you have flashed before than your USB ports should be okay. And if you have already installed the drivers than they still should be on your pc. Try a different USB port and a dedicated one not through a USB hub and make sure it it standard USB and not USB 3.
But if you can't get it into recovery from not been plugged in than I suspect something else
</form>
Do not confuse recovery mode with flash mod!!! They are different e.g. in flash mode a different device shows up in Windows device manager than recovery mode!!!
If the tablet does not show up in the flash tool, then you are not getting it into the correct mode. Sorry I do not know how to do that on the 9G2 as I know it is a little different than the 10G2. However the biggest mistakes I see peiople make is holding buttons and stuff way too long. Many sintructions say to hold reset for 10 seconds. THAT is incorrect. In fact on the 10G2 you hold volume up and just press the reset pin hole for 1 second NO MORE! Then hold volume up for about 3 seconds or until you hear windows BONG a device. If you hold volume up too long, it goes into recovery mode NOT flash mode!
Sorry Bob I meant flash mode
</form>
Ver 1.2 to GingerComb
Hello Bob. let me see if i can ex[lain this correctly, i have the Arnova 9 G2 flashed with your 1.2 ICS rom, im trying to get this Gingercomb flashed but when i try to load the driver from the rockchip batch tool 1.4 Its not working....i believe its because when the device is connected to my computer in flash mode, its showing in device manager as AN9G2I
any help will be appreciated
When you say trying to load the driver from the flash tool. Why are you trying to load a driver to flash. Once your drivers are installed than you don't need to load drivers ever again
</form>
Originally posted by Damo View PostWhen you say trying to load the driver from the flash tool. Why are you trying to load a driver to flash. Once your drivers are installed than you don't need to load drivers ever again
Glad you got it sorted !
</form>
Originally posted by Damo View PostWhat does it show up in device manager when your tab is plugged in?
I forgot to mention when I have the tab connected and try to put it into upload mode it says usb device not reconised
TIA
update
Sorted well kind of, Idug out an old compaq laptop running win xp and it worked on that a bitslow but did the job, I think the samsung software I installed for myphone has messed the drivers up on my win 7 laptop, not sure how tosort it but I will try a restore later to see if that helps, anywaythe old laptop can stay as my arnova programming laptop, thanks for all your helpand hope this will help anyone else having this kind of problem.Last edited by steviep; 27 July 2012, 09:40.
Thank you !
</form>
My arnova 9 g2
Originally posted by l3xxybaby View PostRight, tested a number of games and these are what I got from them:
Angry Birds: Stutters at menu and sometimes pauses for a slight second in game. Changing Chainfire settings cured this.
Assassins Creed - Altaïr's Chronicles: Cropped menus (image seems to be pushed down the screen leaving a huge black border at top) and in game 3d graphics are white making people look like ghosts. Couldn't seem to fix this with varied chainfire settings.
Asphalt 6: Says not supported.
Canabalt HD: Has a couple of graphic glitches in HD mode, but runs very smoothly.
Dead Space: Working smoothly with Qualcomm and reduced texture quality.
Duke Nukem 3D: PERFECT.
Dungeon Hunter: Has the weird pushed down screen thing that AC had on the menu, but in-game is perfect.
Frontline Commando: PERFECT.
Fruit Ninja (Original): PERFECT.
Fruit Ninja THD: Gets through Openfaint fine then crashes to desktop. Couldn't get it working with any settings or plugins.
Minecraft Portable Edition: PERFECT. Even with fancy graphics.
Rebuild: PERFECT.
Riptide GP: PERFECT. (Surprised me tbh)
Shadowgun: Working with Qualcomm/PowerVR and reduced texture quality.
Sonic CD: PERFECT.
Sprinkle: Gets to menu and after selecting new game, returns to desktop.
Temple Run: PERFECT.
That's it so far. Any other games I try out I will let you know the results Bob. =]
Lex.
BASKETBALL SHOT: Force close every time i opened it.
How come my arnova 9 g2 doesnt run temple run perfectly? O_O i installed chainfire 3d pro with nvidia plugin. I even tried other plugins. Still temple run is not running very smooth.
There are currently 2301 users online. 0 members and 2301 guests.
