Arnova 9G2 Finless Bob's "GingerComb" Custom ROM Version 2.1 CWM Release
    I have read that some SD cards can have a problem with CWM. There is not much I can do about that. It's called a RW race condition and has to do with low level code.
    What is the rating e.g. "class" of your SD card?
    You will see on the card a number with a C around it. If you do not have that then your card is sub-standard and probably cannot handle the write speeds CWM is trying to do. If you have a class 6 or above, I understand from studies that it should work.
    Ah there's the problem then, mine is a 32gb class 4 -_-
    No worries, i'll just always backup to internal memory instead =]
    Cheers for the heads up Bob.
      Anyone able to upload the file elsewhere? The download link says the file is missing.
        Have a look here http://www.android-hilfe.de/archos-a...ml#post3599861And here @Post 33: http://www.freaktab.com/showthread.p...ll=1#post16663
          Thanks, I knew I'd seen another thread somewhere but couldnt find it!
            upload mode
            I've tried reset and menu plus other ways around but I just get it into upload mode this time, help please
                problem loading widget
                Ok got the rom loaded but I get 2 missing widgets on the home screen, tried another upload and its
                still the same, can anyone tell me what these widgets are, also should the be a browser installed ?
                thanks
                  thanks
                  Just remove them from the homescreen they are old ones. Remember this is a beta test Rom. So when testing is complete a full 2.1 Rom will be produced with the App injector package etc in
                  Sent from Xperia Mini Pro ~ Android 4.0.4 ICS
                  </form>
                    Release version updated!
                    UPDATE July 10, 2012
                    I have updated this ROM based on feedback and bugs found;
                    This is still my 2.1 ROM but the new ROM is 2.1a. It has the following fixes in it:
                    1) System space has been increased from 240mb to 300mb. This is because the standard APP Injector package would not fit on /system.
                    2) WPA_supplicant was updated to support ADHOC network connections.
                    That is all. If you do not need more system space or adhoc wifi, then there is no reason to update to this ROM.
                    However with that said, you CAN update and use a backup in CWM to do a "advanced" restore of the data and cache areas. Thus you should not loose all your APPS, etc.
                    If you want to try this approach, do not erase IDB and only flash system.img. If the system does not work right... well sorry. Just do a full reflash and erase IDB. I cannot test every scenario of apps installed. But again I do believe you can flash system.img alone and still be OK.
                    The download link in the first post of this thread has been updated. Click it and you will now get 2.1a ROM.
                      thank you
                      edit:
                      sorry for my approximatly english , but i'm french
                      So, i did not succeeded to download this ROM .... how i do it please? thanks
                        Hi Bob,
                        just flashed Gingercomb a few minutes ago after trying your ICS that denied to install the Google voice engine.
                        Looks pretty nice and all is working so far well.
                        Well done, feels much better than ICS.
                        The design is superb, all looks and works much more professional than all I saw and tried before.
                        Very impressive.
                        Thanks.
                        One thing,
                        where can I customize the background (wallpapers, live background) ?
                        The matching topic in Display settings from ICS is missing here in Gingercomb.
                          Originally posted by RK_64 View Post
                          One thing,
                          Glad your enjoying GingerComb!
                          As for the ICS stuff. I wish I could help! I do not even know what your talking about with settings in ICS related to GingerComb
                          I do not have anything that runs ICS yet so I do not even know the stuff available in ICS. Yes I am doing ICS ROM's now but only "in the dark" and upping the performance, etc. I am not doing any Android user level stuff yet like I did with GingerComb. Sorry man... Soon I will have a Tab with ICS and can learn to tweak ICS itself!
                            No problem, it is all there, i found it some minutes after I posted my question.
                            In ICS, the background and live-wallpapers are set within the settings - display tab.
                            In Gingercomb, you have that topic in the status bar.
                            Just a bit of search and time to discover what is where, but all seems to be implemented and works fine of what is needed for daily use.
                            Just to save me some time, can you tell me what folder contains the wallpapers so I can add some custom ones?
                            There is no option in the dialog to choose a picture from a custom folder.
                            But again, by far the best ROM for the 9 G2 that I tried so far.
                              Just download any wallpaper and put it anywhere on your sd card
                              Open the gallery app and it will find the photos automatically. Select the picture you want and you than have option to set as background.
                              I personally prefer quickpic from the Playstore
                              Much better than the stock gallery app and also has the option to set any image as wallpaper
                              Sent from my SK17i using Tapatalk 2
                              </form>
                                Yes,
                                that works fine.
