S89/S82 Finless 1.5 ROM
    OK so it's here
    My 1.5 ROM. This is based on the S82/S89 102K4 ROM.
    Need I say more?
    ____________________________________
    Features and release notes for my 1.5 ROM:
    1) Properly rooted using SuperSU. What does properly mean?
    Android 4.4.2 requires SU to be running as a daemon now. There are many ways to run this as a daemon.
    Most roots so far are using a install-recovery.sh script or if init.d is enabled, a init.d script.
    This means you could lose root if messing with these scripts which some rooted apps do!
    What I have done is started the daemon in init.rc thus eliminating the need for boot scripts!
    This took me a while to learn to do! Enjoy a BETTER ROOT!
    2) Updated Google framework and Play Store core files. The ones in the stock ROM were out of date.
    On first boot NOTHING will need to be updated once you logon to Google Play.
    That is as of this date.
    This may fix paid APP install issues but I do not know as I never have bought APPs and can't test.
    3) Debloated of junk APPs and Google Apps you can get from Google Play.
    There was quite a few useless hidden apps in this KitKat release! Some of them did not even work.
    I did remove XBMC and other pre-install APPs as well. I like a CLEAN ROM that you the user can setup the way you want.
    Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer).
    If you want the original XBMC APP then download it from Geekbuying.com
    4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
    This time around due to updated security in 4.4, init.d was a lot harder to get working.
    Again I had to figure it out!
    5) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
    I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
    This should also allow Netflix HD but I have not tested it.
    Your device will show up in google play as Nexus 10 device not a Vega S89! Understand this please.
    I also left the original build.prop in the ROM called build.orig.
    If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
    Then rename build.orig to build.prop.
    Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
    Reboot! You should be back to showing up as a Vega.
    7) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
    8) Carrier spoofs for better APP compatibility.
    9) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
    10) Added bonus! CPU fixer patches!
    In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor.
    See the README.txt in that folder for an explanation and how to install them.
    ________________________________________________
    OK so here is the download!
    READ the README.TXT in the zip for instructions!
    ROM -> S82/S89 - Finless ROM 1.5 (351 megs)
    thanks Bob! will check it out tonight (approx. 8 hours fron now).
      Download link also fixed... Thanks for letting me know.
      Sheesh.... that's what I get for copying older posts and modding them
        I will try it ,anyway all ur rom's are better than the factory
          You are the best Bob, thanks very much for your hard work.
          Sent from my GT-I9300 using Tapatalk
            I just watched a movie on Netflix....
            HOLY SH*T.... Better than from my PC!
            This box is ROCKIN
              I noticed that I have to install first the new update 102K4 than this one,it will not work if u want to install it on top of 1.4
                That should not be the case. This updated flashes everything (like 1.4 did) But maybe I missed something.
                What doesn't work and what did you have flashed before?
                I need exact to test what your condition was to recreate the issue.
                  I have the 1.4 on top of the 101k4 plus the 5Ghz zip, but if I try to install the 1.5 it start but stops after few sec and say header is invalid? Package is not verified something like that I will make a picture latter on now is 1am
                    There is no 1.4 on top of 101k4. 1.4 is a full ROM flash and replaces everything. But 1.4 is built from 101k4.
                    The 5G patch only replaces one file.
                    I will try what you did and see if I can repeat it.
                    YOU DID un-zip the download into it's parts yes? If you try to use the zip as downloaded it will fail.
                      I.... carumba.... YOU DID...
                      I swear.... I write readme.txt and instructions hoping most can follow them. I guess not
                      Dude... unzip the file you downloaded and read the readme.txt
                      I just tested going from 101K4 flashed with the AML flash tool, to 1.4 and then to 1.5 and no issues.
                      So I decided to see what would happen if I put the downloaded zip on SD and tried to use it....
                      BOING..... error OF COURSE! The downloaded zip is all the stuff you need. It is not flashable!
                      Inside it is the readme, the correct zip to flash, patches, and other goodies...
                      Like my 1.4 ROM... same thing.
                      YOU have to unzip the download!!! My ROM's are all like that!
                      Is this not understandable?
                      Sorry to be harsh but sheesh......
                        Every forum, 85% NeVEr ReaD. Ever.
                        Even if you put a reminder... Like big words "READ ME" and then instruct them to read the 'readme', it never fails. I would never flash things to an expensive device until I read and fully understood.
                        Btw 90% don't search either. Some even when answers are on same page.
                        Not directed solely at dude who rushed, but this is a big problem in general. I do understand impatience sometimes too
                        Beautiful boot animation Bob! Thanks for your work.
                          This box is ROCKIN
                          Did you get HD on netflix?
                          ~Gopichand Pai
                            403 Error on Google play
                            Hello
                            Installed it on S89 Elite and I get 403 error when trying to install application from the store...
                            Oren
                              Originally posted by orenmd View Post
                              Hello
                              Oren
                              hey! Same here with standard one.
                              Seems a bug of 1.5 version...
