S89/S82 Finless 1.5 ROM
Originally posted by Brinis View Posti have a mouse that dos it to and then i have one where it works fine and its on the same box. so think its the mouse maybe
does it do this everytime you use it, or just when you start using your mouse after inactivity? Did you install any of the cpu patchers? If so which one? While this is happening what is your temp and cpu frequency? Is your ram used up? there can be many factors in this. on any stock rom the cpu throttles when hot. if you did use the cpu patch maybe you have one of the boxes that have problems at lower frequencies.@µ$ł!Ω
Originally posted by Nowandlayda View Postdoes it do this everytime you use it, or just when you start using your mouse after inactivity? Did you install any of the cpu patchers? If so which one? While this is happening what is your temp and cpu frequency? Is your ram used up? there can be many factors in this. on any stock rom the cpu throttles when hot. if you did use the cpu patch maybe you have one of the boxes that have problems at lower frequencies.
Originally posted by Nowandlayda View Postoh your using "launcher 3" that launcher blows harder than kenny g. Get a new launcher bud. I had a 5 second lag with that amlogic crap.
wanam cpu if I'm not mistaken is a xposed module. If it is, what tweaks are you using? Also are you using ART or dalvik? If you are tweaking system paramaters with anything make sure its compatible with all variables. If not, without logs I don't think anyone can help you bud.
i put the 1.5 on the other box to now the 16g and there it runs fine to also no cpu fix i get 30K on both and both show the 19xx cpu. and remote works fine on both to.
Originally posted by Brinis View Postthis is working so good on my elite. ill test it on the otter one later. but why do we have to use the cpu_fix. ? it runs fine. so is there a need to use it. ? will it change something. ?
I just use the box for xbmc
Alternate keyboard
This is for anyone wanting the alternate keyboard I removed from the stock ROM.
Basically the stock ROM had 2 keyboards. The AOSP and the English Remote Input Method. I removed this keyboard and left the AOSP keyboard.
Some want it back so here goes.
Download this zip. Do not unzip it. Put it on SDcard and install it the usual update way. Easy way is to use the update APP. This will install the Remote Keyboard Input Method that I removed from the ROM.
https://drive.google.com/file/d/0B9B...it?usp=sharing
To use it:
1) Go to setting and Language and Input
2) Turn on the Remote Keyboard Input Method (check box next to it).
3) Go into Default (click the line) and select English - Remote Keyboard Input method.
Your done and now have the other keyboard back.
Originally posted by Finless View PostThis is for anyone wanting the alternate keyboard I removed from the stock ROM.
To use it:
Would that be needed if one would like to use a bluetooth keyboard?
I just don't have all the hardware out there to test stuff with so it is impossible for me to know everything about every keyboard, mouse, joystick, gamepad, etc.
There are currently 1873 users online. 2 members and 1871 guests.
