UPDATE: The Ultimate UPDATE 6/9/2014 ...
Join Date Oct 2013 Location New York, New York (The Big Apple) Posts 737
NEW ULTRA 1080p Multi-Media Super ROM {Superior Picture Pixel* Crystal Clear Video Resolution Quality} Download It In Post Number ONE, Just Follow The Download Instructions {Thanks To My Good Buddy Mr. Sammy} ...
ShowBox and Video Mix Built IN {First Run Movies}
The New ShowBox and Video Mix Built IN {First Run Movies} Multi-Media Super ROM is now ready for download, {See Fast Download Links Below} ... Plus a ton and a truck load of all the Multi-Media Entertainment you will ever need all one Android TV Box {LibMedia.so Hack Ready} .... LIVE TV/SPORTS 24/7. World Cup Soccer App Built IN ....
GMail Tip:Update the GMail app, let this be the first thing you do and copy the GMail icon shortcut to your second slide apps screen, keep it there ... Doing it this way, the GMail icon will not disappear on reboots ...
1080p DOWNLOADS:
ULTRA-1080p Multi Media Super ROM DOWNLOAD NOW
*Get This ultimate Super ROM 1080p 2MP Version HERE
https://plus.google.com/communities/...artnerid=gplp0
*{Scroll Down to post number 9999, Click on READ MORE to expand the post, there you will find the fast Download links}
*Get The Ultimate Super ROM 1080p 5MP Version HERE*
*ConVic Tech Playercorefactory.xml File DOWNLOAD:
*You can get the ConVic Tech "Playercorefactory.xml" file HERE http://www.mediafire.com/view/53yjv3...orefactory.xml ...
*PLEASE NOTE: ALL MY ROM BUILDS ARE USA BASED, MEANING YOU WILL BE USING A USA GOOGLE PLAY STORE (If You Are Using A VPN Set Up) All my multi-media apps are USA based ...! (NONE OF MY MULTI-MEDIA APPS ARE EUROPE BASED), Plus Your Android TV Box Will Not Run HOT Using The Above ROM Builds ...!
The CR11S/CS968 UltraTV1ONEPackage Has Been Upscale With NEW Multi-Media TV Apps
1.\ SonyWalkman.apk
2.\ Addblockplus.apk
3.\ Flashplayer.apk
4.\ Dolphin Browser.apk
5.\ YouTube.apk
6.\ MXPlayer.apk
The Dolphin Brower is not made the default browser, if you desire, you can still add the HTML5 NEW Google Chrome browser ...
Their is still a lot of diversity in these ROM builds, you can go with the Convic Tech package {Built IN} or use the built IN Beyond XBMC v3.4 with the "LibMedia.so hack or use the XBMCZ with the Convic Tech package/LibMedia.so hack, your choice ...
These ROM builds are now truly the ultimate multi-media super ROM "UltraTV1ONEpackage with a huge amount movies, TV entertainment apps, LIVE Sports 24/7, plus speed and ultra high picture pixel crystal clear video resolution quality ...
The ROM builds below are now being pulled and will be replaced with the Ultra Multi-Media Super ROM Sports Package and Movies, TV Entertainment Package BUILT IN ...
1.\ The Ultra Multi-Media Super ROM Sports Package
A.\ WatchESPN Live Sports 24/7
B.\ World Cup Soccer {ESPN FC}
C.\ UFC {Wrestling, Prime Time Fights, Plus Pay-per-View Events} Performers: UFC - Ultimate Fighting Championship
2.\ The Ultra Multi-Media Super ROM Movies, TV Entertainment Package
A.\ HBOgo {TV Series and Episodes}
B.\ Xfinity TV Go {Basic Cable Package and On Demand Video/Movies}
C.\ Netflix {Movies, TV 24/7}
D.\ Vudu Movies and TV {Current Movie Release}
F.\ FilmOn Live TV {Live TV 24/7}
These NEW ROM Builds CS11S/CS969 AP6210 2MP/5MP are being uploaded now, so please be a little patient ... {Fast Download Links Will Be Available}
9999: NEW CR11S/CS968 AP6210 OFFICIAL CUSTOM 4.4 KITKAT Multi-Media Super ROM5
{JUST RELEASED 20140526. ENHANCED VIDEO RESOLUTION QUALITY, BUILT IN UPDATED NETFLIX, LIVE TV, AND BEYOND XBMC {WORKS WITH THE CONVIC TECH XBMC PACKAGE}
"See The Difference"
GO TO DISPLAY> SCREEN> HDMI MODE> AND SET YOUR BOX TO 1920x1080p-60 AND YOUR TV VIEWING EXPERIENCE SHOULD BE LIKE THE TOP PHOTO BELOW, {ALL MY ROM BUILDS HAVE ENHANCED PICTURE PIXEL CRYSTAL CLEAR VIDEO RESOLUTION}, NO 1080p HACK NEEDED, ENJOY ....!
1080p DOWNLOADS:
AC3 DTS PASS THROUGH VIA THE PLEX SERVER USING THE BUILT IN "BEYOND XBMC" V3.4:
I want to correct something, that I have been meaning to correct the above new feature is a AV out feature ...!
AC3 DTS PASS THROUGH VIA THE PLEX SERVER:
Convic Tech Package Here: {This Can Only Be Activated Via This Package ONLY Using The MXPlayer {No Custom Codecs Required} ...
A awesome guide for setting up your Beyond XBMC or Gotham XBMC by Convic Tech https://www.youtube.com/watch?list=U...&v=0XrH1JVQb7w
I like this set up because you can have AC3 DTS with either your Beyond XBMC or Gotham XBMC ... It makes the MXPlayer the default player for local media files playback {No Custom Codecs Must Be Installed For AC3/DTS} ... It makes the Wondershare player the default XBMC DVD player {Use This Wondershare Player found here ONLY https://play.google.com/store/apps/d...ershare.player .... DO NOT USE THE WONDERSHARE PLAYER IN THE PACKAGE BELOW, IF YOU ARE USING A CR11S/CS968} ...
Here is the apps set up package including the playercorefactory.xml file for the CR11S/CS968, just install all the apps in the package, EXCEPT THE WONDERSHARE PLAYER http://www.mediafire.com/download/cd...13-14_Files.7z ... PLEASE NOTE: I'M THINKING EVERYBODY KNOWS HOW TO INSTALL THE
{Playercorefactory.xml FILE}
