ULTRA 1080p Showbox/Video Mix CR11S/CS968 Multi-Media Super ROM AP6210 LIVE TV/SPORTS 24/7, {WORLD CUP APP READY}
    LibMedia.so Hack Sound Issues
    By chance if you should encounter any audio issues via the LibMedia.so hack, the complete fix is to install the app "SoundAbout Pro Key" with license $2.99 well worth it too ... Go to "Media audio: Check the circle "Aux Digital (HDMI) back out, you are done ...!
      Hi Tech1, I'm done now. But my WIFI and bluetooth are not working any longer after that. Any idea of what to do?
        Now this tells us the ROM you installed is not for your box, you will have to unscrew {Take Out} the four bottom screws on your Android TV box {EASY} ... You need to find out which WiFi Chip is on the board .... Then we can tell you which ROM build to use .... Their is a thread here that explains, what to look for and where the WiFi Chip is located, we need the name of your WiFi Chip ...
        PLEASE NOTE: ALL MY ROM BUILDS ARE USA BASED, MEANING YOU WILL BE USING A USA GOOGLE PLAY STORE (If You Are Using A VPN Set Up) All my multi-media apps are USA based ...! (NONE OF MY APPS ARE EUORPE BASED)
          Hi tech1,
          I did as you mentioned. The wifi chipset is Mediatek MT5931SA / MT6622N bluetooth.
          And my board number is HTC-T018-V4.
          Its all identical to this one http://blenderboydiaries.blogspot.se...kchip-etc.html
            Hi tech1,
            Sweet, test my NEW MTK Multi-Media Super ROM "UltraTV1ONEPackage Built IN" LibMedia.so Hack READY, also Convic Tech READY found HERE http://www.freaktab.com/showthread.p...-so-Hack-READY ...
            Let me know how everything works ASAP, enjoy ...!
              ConVic Tech Playercorefactory.xml File DOWNLOAD
              *ConVic Tech Playercorefactory.xml File DOWNLOAD:
              *You can get the ConVic Tech "Playercorefactory.xml" file HERE http://www.mediafire.com/view/53yjv3...orefactory.xml ...
                Hi tech1,
                The WIFI and bluetooth are working, aslo the sound.The only problem I see now, is when I'm uninstalling apps from the ApkInstaller it says that they are uninstalled. But they are not, they are still appearing.
                  "Uninstaller" By Rhythm Software
                  Hi tech1,
                  Sweet, Easy fix, go to the Google Play Apps Store and get the app "Uninstaller" By Rhythm Software, use this uninstaller ONLY ... Once this uninstaller is installed, you will easy be able to uninstall all your apps ...!
                    Hi tech1,
                    Unfortunately the "Uninstaller by Rythm" only show me the Apps list (the one under Settings) to uninstall, not the apps in the ApkInstaller
                      Hi tech1,
                      Slow your roll, I'm here to help, you are new in the game ... The Uninstaller is for uninstalling apps, you have to left click on the app you want to uninstall, a drop menu will appear, click on "Uninstall" ... Let me know how it works out for you ...
                      Also you can uninstall apps under Settings> Apps ...!
                        Hi tech1, I will decribe it for you.
                        On the desktop there is an icon with the name ApkInstaller, once I click on it, i have three choices (Install, Manage, Exit). When I click on Manage, i see a list of apps. I click on one app, then i see the choice to Uninstall, once i click on Uninstall, it ask me "Do you want to uninstall this app?" I click on OK, then it verify for me "Uninstall unseccessful".
                        Notice. The Apps (the one under the settings) does not show the same apps under the ApkInstaller
                          I understand what you are saying, that's why I told you use the left click method with the Uninstaller app
                          By Rhythm Software ... It's the easiest way to uninstall apps on your TV box ...
                          By the way, have you rooted your box yet ...?
                            Hi tech1,
                            Yes, It works to left click and uninstall the app in the Uninstaller App. But the problem is that i dont see the apps like NewsQuical!, Fancy Widgets, Weather & Clock Wid and all other apps which appears in ApkInstaller. They are not showing there (in Uninstaller app by Rhythm). I can only see them in ApkInstaller.
                            yes, the device should be rooted, I used Root checker. (I rooted it after i flashed rom)
                              I always use the Uninstall Master from Google Play, there you can choose system apps and uninstall every app there is, but be beware of what you delete so it doesnt affect your system. You need to be rooted to delete system apps, (I think).
                              Have you tried to right click on the APP (NewsQuical) you want to install? and not in the actual uninstall app?
                              Hi tech1,
                              CR11S AP6210 Chipset
                              CS968 MTK Chipset MT5981 - MT6622
                              HTC-T018-V04
                                I managed to uninstall it with Uninstaller Master, it asked me to be granted root access, and I granted it.
                                Strange that the ApkInstaller didnt manage that, maybe it lacks root access.. I dont know.
