Στάλθηκε από το SM-N9005 μου χρησιμοποιώντας Tapatalk
ULTRA 1080p Showbox/Video Mix CR11S/CS968 Multi-Media Super ROM AP6210 LIVE TV/SPORTS 24/7, {WORLD CUP APP READY}
Originally posted by spyrosrotary View PostWhich is the correct way? I run batch tool, and I press restore button as usual!
Originally posted by Tech1 View PostFirst of all, lets make sure these ROM builds are for your box ... Unscrew the bottom 4 screws on your TV box and find out which WiFi board you have ... Their is a post explaining where to locate and find the name of your WiFi chip ...
UPDATED New ROM Builds With VPN tun.ko File BUILT IN
Originally posted by spyrosrotary View PostIt's the correct version. I have the AP6210 wifi chip. I have flashed your previous roms and everything work great. But this version really doesn't work to me!
VPN1CLICK Built INTO The {New Google Android TV 1080p 4.4 KitKat Multi-Media Super ROM} See Post Number ONE For The Download Instructions Links ...
Απ: ULTRA 1080p Showbox/Video Mix CR11S/CS968 Multi-Media Super ROM AP6210 LIVE TV/SPORTS 24/7, {WORLD CUP APP READY}
Originally posted by Tech1 View PostTest my new ROM Builds I just uploaded with the new added VPN tun.ko file ... Let me know ASAP if these ROM builds work better for you ...
Review
Ok, I had a chance to download this rom and here is my quick review:
1) I had no issue flashing the rom. It took like 10-15min after bootup to do the install/setup so just have to wait a bit. After that I did the root and worked like a charm. I had to install the update from playstore for SuperSu app and it should be version 1.94(latest), then it download the binary and now I have full root.
2) The rom itself is very smooth and snappy, definitely better than the 4.2 version, wallpapers are working fine, auto hide system doc bar is working well too. The resolution/density is excellent, crisp and sharp specially when I watch 1080p movies. The browser is much faster than 4.2. Only 1 thing I don't like is the sound volume settings, it only has 1 option volume for the sound unlike my 4.4.2 rom by Wasser on my T-R42 device, which has 3. Another thing with the volume is while watching a movie and I turn down the volume to my liking, then I need to check my email and when I got back the volume is max out, so I have to turn it down again.
3) This is my biggest issue since I'm a movie freak. Beyond XBMC sucks on 4.4 kitkat, it's the best on 4.2 but it just not working well on 4.4kk. So I download the original xbmc gotham 3.1 latest and voila, it's working beautifully. Yep, Beyond xbmc 3.4 is not recommend on 4.4.
I'm watch 1080p movie right now with Gotham and it's crisp and so smooth like using disc. BTW, I don't have to play with any settings, just installed by default. So at the end, is it worth to upgrade?? hell YES and just install Gotham xbmc 3.1 and you all set...until Flumpster release the new version of Beyond xbmc. One really nice thing about this rom is Tech1 loaded with so many entertainment apps that you will never need to look any where else.
Summary: Pros - Rom is fast, smooth, snappy and fully loaded with many entertainment/ultilities apps. Cons - Volume reset to max which is a must fix and pre install Beyond XBMC, but this could be fix easily by install the Gotham version. Well that's it for now and will update if find anything else...good or bad. Happy testing everyone!Last edited by buhohitr; 12 June 2014, 16:45.
1080p Video Playback Via BeYond XBMC And Built In 1080p Hack For Gotham XBMC/XBMCZ
No Stuck ON Boot Or Vertical Lines IssuesPlease Note: We do NOT have any stuck on the boot logo or verticle lines issues with any of my ROM builds ... ALL my ROM builds boot like they are suppose too, enjoy ...
Thanks for your review, please note, just about ALL of the built IN multi-media apps can be uninstalled, if you desire too ... They are not system apps ...!
How to Play 1080p movies via the Beyond XBMC v3.4, when the movies first start, just press the "C" key on your keyboard or backside remote keyboard ... A drop menu will appear with the option to use the MXPlayer ... You can get AC3 DTS digital audio via using the MXPlayer with custom codecs ...
Their is a link built into the MXPlayer giving direct access to the current custom codecs for AC3 DTS digital audio to use with the MXPlayer ... Please do NOT use the MXPlayer Pro version or have it installed on your TV box, because it will stop the drop menu from appearing, enjoy ...!
*Also their is a built IN hack to make large 1080p {Files} movies playback smoother via the Gotham XBMC or the Gotham XBMZ, enjoy ...Last edited by Tech1; 12 June 2014, 14:53.
Originally posted by spyrosrotary View PostI'll flash the box asap! I am using your super media rom and it's ok!
New Updated ROM Builds Just Released, Word Cup Soccer Apps READY
Originally posted by spyrosrotary View PostI tried the Google Android TV 2MPZX12 Multi Media Super ROM 1080p-AP6210-20151231 rom but the box didn't boot(vertical lines). I tried CR11S-Tech1-CS928-2MPXX-4.4KitKat-UltraTV1Package-Super-ROM-AP6210-20140704 rom and the box boot again!I don't know why this version doesn't boot!
LibMedia.so Hack (4.4 Kitkat ROM Builds) Wasser's Link
You can get the {LibMedia.so Hack} file at Wasser's link that works with 4.4 KitKat ROM builds here https://docs.google.com/file/d/0B3xq...MtXzNLOGM/edit ...
If you desire to restore back to the original LibMedia.so file, you can get it here http://www.mediafire.com/download/oo...iginal_File.7z ...Last edited by Tech1; 15 June 2014, 13:18.
Originally posted by buhohitr View PostHi Tech1, so exactly what are the differences between your rom and Quickshot rom?? Thanks
There are currently 2250 users online. 2 members and 2248 guests.
