ULTRA 1080p Showbox/Video Mix CR11S/CS968 Multi-Media Super ROM AP6210 LIVE TV/SPORTS 24/7, {WORLD CUP APP READY}
    Latest 5MP rom 17.7 review
    OK, I have being running the latest version 17.7 Rom for a week and here is my short summary:
    Pros:
    - HD thumnails/icons (very sharp compared to the older version).
    - Smooth and quick
    - XBMC is streaming smoothly and very sharp with 1080p, One feature I missed from the old Beyond 3.4 is that when I pause the movie, it displayed the movie description. I heard from Flumbster that he enabled one of the feature in the skin. The second thing is that it should come pre-configured with sources like (fusion,mashup,xfinity), It would be nice for a quick setup. I was able to install all my top notch movie add-on like mashup, icefilm,1channel,GOMovies, GOTV, Glow Movies HD and Yify Movies HD, IWO-watch. I would rate the xbmc build in a 9 out of 10.
    - Pre-root works nice, but need to update from play store.
    Cons:
    - Quickboot and Android weather are not working.
    - Reboot randomly needs to pull the power in order to boot up. (was't an issue with the old version). Only happened twice for me, but since I don't reboot the device that much so no issue here.
    Summary: This latest version is the best, video/thumbnails/images are super sharp (even SD is high quality) and 1080p streaming beautifully. Wifi/ethernet/bluetooth/mouse/keyboard are all working as expected. Once the rom settle, the rom is very smooth and snappy. I'm very happy with this version. I will update this once I see anything else. Cheers and again THANK YOU TECH1 for another great build. Hats off to you Sir!
      Pros:
      - Smooth and quick
      Cons:
      The 17.7 was suppose to be a secret version, but I did not tell you that ...(lol)
      I believe this version was already pre-rooted ... Tell me how the 5MP camera works on the 17.7 ... Oh! I remember now, I sent you this ROM build as a private tester, ok, yeah ... Thanks a million for your evaluation ....! I see we like the very same XBMC addons ...(lol)
        Mirror Technology
        Mirror Technology, Mirror On The Wall/TV, Mirror Cast Your Android Smartphones/Tablets To Your Big Screen TV In Real Time Via ChromeCast ...
        {Folks This Is No Flim-Flam, It's The Real Deal}
          Screen Casting Via ChromeCast
          Screen casting via ChromeCast will require Android 4.4.1 or higher (MR1) and is currently supported on the following devices ...
          • Nexus 4
          • Nexus 5
          • Nexus 7 (2013)
          • Nexus 10
          • Samsung Galaxy S4
          • Samsung Galaxy S5
          • Samsung Galaxy Note 3
          • Samsung Galaxy Note 10 (2014)
          • HTC One M7
          • LG G Pro2
          • LG G2
          • and LG G3
          You should be able to access the casting menu in display options and select your Chromecast. The Quick Settings icon we've been seeing on stock devices for months seems to be live as well. It's also in the Chromecast app, which finally makes that app useful beyond setting up the dongle. The screen is beamed over without any further fiddling ...
          Video seems okay (depending on network) with some artifacting, but audio goes over fine. Sound still works with the screen off too...
            Hi Tech1, my 5MP camera is working fine, no issue.
              [EXPERIMENTAL] ENABLE MIRRORING FROM ANY DEVICE]
              Some of you may have heard of me before, and for the ones that haven't, let this be a warm introduction.
              After hearing of the new Chromecast app with Beta support for mirroring, I decided to see if it's possible to enable for all devices. Apparently it is!
              I assumed that some devices just wouldn't stream well, so I decided to mark this as [EXPERIMENTAL]. Please note that I did not make the feature, just the method to enable it.
              Please note that you need the latest version of the Chromecast companion app and root access on your device (not your chromecast) for this to work properly.
              LINK:
              MirrorEnabler.apk | MirrorEnabler.apk | by r3pwn-from-xda for Generic Device
              Tested Working:
              (Aside from the officially supported devices)
              ASUS PadFone 2
              Droid RAZR MAXX HD
              Sony Xperia Z2
              Sony Xperia ZL
              Sony Z Ultra
              HTC One M8 (Including GPE)
              Motorola Moto X
              Motorola Moto G
              Samsung Note 8 Tab
              Samsung Note Pro 12.2 Tab
              Nexus 7 2012
              QHD Find 7
              LG GPad 8.3
              NVIDIA SHIELD
              Mixed Reports:
              Samsung Galaxy S III
              Samsung Galaxy Note 2
              Tested Not Working:
              HTC EVO 3D
              Galaxy Nexus[/B]
              The above XDA thread is here [EXPERIMENTAL] Enable Mirroring from any device - XDA Forum ...
                {Fox Sports Go} Coming To The Next Android TV Multi-Media Super ROM Update
                The {Fox Sports Go App} Will Be Added/Coming To The Next Android TV Multi-Media Super ROM Build Update ...
                Some of you maybe asking why do I add these upscale apps to my Multi-Media Super ROM builds ... Simple most of these app CANNOT Be downloaded from the Google Play Store direct to your Android TV box ... A lot of these apps have to be modified to work on your Android TV box ... Again ALL the Multi-Media Super ROM apps can be uninstalled, they are not system apps ...!
                Enjoy the best Multi-Media Super ROM package on the market for your Android TV box ...!
                  Tech1, I don't know how hard it is but if you could create an upgrade rom that doesn't wipe data would be nice, just a thought. Many people here would not upgrade just for one additional app and they have to redo the setup again.
                    I think you missed my point about apps you cannot download direct from the Play Store to your Android TV box, it's more than just a few apps in my Multi-Media Super ROM builds ...
                    I know exactly what you are talking about restoring your data, which would make it easy to put back all your favorite apps and save a lot of time, we think ... When I was building Smartphones/Tablets ROM builds, I did exactly as you described above ...
                    Then I discovered, while restoring my data back to my devices, their would never be a 100% restoration exactly as before, data would always be missing, causing my devices to work/operate with erratic behavior... That's the reason why I stopped building ROMs with the restore feature ....
                    It's always better to take your time and rebuild your current new ROM build installation each time you install a new ROM build ... It may take some time, but it will save you a lot of headaches in the long run ...
                      app update
                      It would be easier just to share the new softwares .apk files.
                        Rooted CR11S 1080p AP6210 Android TV 4.4 KitKat ULTRA-EXTRA-PLUS-SPORTS TV-ENTERTAINMENT-PACKAGE
                        NEW Just RELEASED 7/17/2014, Official/Custom Rooted CR11S 1080p AP6210 Android TV 4.4 KitKat ULTRA-EXTRA-PLUS-SPORTS TV-ENTERTAINMENT-PACKAGE-Google Android TV Multi- Super ROM With The most APPS, PLUS ALl The Super ROM apps {LibMedia.so Hack READY} ...
                        The Ultra-Extra-Plus-SPORTS TV- Entertainment Package, NFL, NBA, "FOX SPORTS GO", Major League Baseball {MLB}, Major League Soccer {MLS}, *UFC, ESPN, LIVE TV SPORTS PRO, LIVE TV FROM JUST ABOUT EVERY USA MAJOR CITY, HBOgo, Popcorn Flix, LIVE TV, ESPN Live Sports 24/7, Mobdro, Google Movies TV Worldwide package, Jazz Radio.Com, CNN News, BET {BLACK ENTERTAINMENT TELEVISION} And Gotham 1.3 XBMC Built IN {LibMedia.so Hack READY} ... The Ultimate Multi-Media Super ROM Package ...
                        {ESPN, Netflix, HBOgo subscription required}
                        *AC3 DTS Digital Audio {LibMedia.so Hack}: Please Go To Settings> Sound Devices Manager> RK29_RK1000 PASSTHROUGH ...
                        *If you are NOT using AC3 DTS Digital Audio {LibMedia.so Hack} Please Go To Settings> Sound Devices Manager> Use RK29_RK1000 ...
                        DOWNLOAD:
                        *Get The ULTRA-EXTRA-PLUS-SPORTS TV-ENTERTAINMENT-PACKAGE-Google Android TV Multi- Super ROM 1080p ROOTED CR11S Super ROM 2/5MPZX19.2 Version, Just Follow The Link Below ...
                        *{All DOWNLOADS From Now On Will Be In The Top Pinned Post NO MORE SCROLLING ...
                        *Get This ultimate CR11S/CS968 Super ROM 2/5MPZX19.2 Version HERE
                        https://plus.google.com/communities/...artnerid=gplp0 ...
                          Tech1, I would like to go back to JB super rom 5mp, I have 2 questions:
                          1) Can you give me the link to the 4.2 JB rom?
                          2) Do I have to flash JB bootloader or it's already build-in with your image file?
                          EDIT: found link for old 4.2 software, so can you help with the second question? do I need to flash the 4.2 bootloader before I reflash the 4.2 rom or it already buld in with your rom?
                            No, just flash it like you always do, enjoy ...
                              CloudnetGO Newly Released Official/Custom Multi-Media Super ROM 1080p Rooted AP6210, VPN Works, LibMedia.so READY
                              VPN Tun.ko File Built IN, VPN Is Now Working Like A Charm ...!
                              If You Should Have Slow Boot Up Issues, Just Pull The Plug And Reboot ...!
                              NEW Just RELEASED 7/10/2014, Official/Custom Rooted CloudnetGO CR11S 1080p AP6210 Android TV 4.4 KitKat ULTRA-EXTRA-PLUS-SPORTS TV-ENTERTAINMENT-PACKAGE-Google Android TV Multi- Super ROM With The most APPS, PLUS ALl The Super ROM apps, VPN Working Tun.ko Hack Built IN {LibMedia.so Hack READY} ...
                              The Ultra-Extra-Plus-SPORTS TV- Entertainment Package, NFL, NBA, "FOX SPORTS GO", Major League Baseball {MLB}, Major League Soccer {MLS}, NHL {NATIONAL HOCKEY LEAGUE}, *UFC, ESPN, LIVE TV SPORTS PRO, LIVE TV FROM JUST ABOUT EVERY USA MAJOR CITY, HBOgo, Popcorn Flix, LIVE TV, ESPN Live Sports 24/7, Mobdro, Google Movies TV Worldwide package, Jazz Radio.Com, CNN News, BET {BLACK ENTERTAINMENT TELEVISION} And Gotham 1.3 XBMC Built IN {LibMedia.so Hack READY} ... The Ultimate Multi-Media Super ROM Package ... {ESPN, Netflix, HBOgo subscription required}
                              DOWNLOAD:
                              *Get The ULTRA-EXTRA-PLUS-SPORTS TV-ENTERTAINMENT-PACKAGE-Google Android TV Multi- Super ROM 1080p ROOTED CR11S/CS968 Super ROM 2/5MPZX19.5 Version, Just Follow The Link Below ...
                              *Get This ultimate CR11S Super ROM 2/5MPZX19.5 Version HERE
                                Where is the link for your version of the latest Cloudness rom?
                                edit: sorry, you're uploading....my bad
