ULTRA 1080p Showbox/Video Mix CR11S/CS968 Multi-Media Super ROM AP6210 LIVE TV/SPORTS 24/7, {WORLD CUP APP READY}
    i downloaded super rom and wifi can`t connect so i`m changing to early rom and this cs968 build in browser can`t play flash always hangs.
      TV FILES MANAGER WORKS ON JUST ABOUT ALL ANDROID TV BOXES
      Description
      TV file manager is a new file manager, it is simple and efficient, can help you quickly manage phone, tablet, even TV files. For users television, we particularly recommend TV file manager, because it is based on (high-resolution) designed and developed large-screen devices, interactive minimalist, only can be done by remote control operation corresponding file.
      If you want to fight the entertainment television processing terminal family, download TV file manager now, so you can access the contents of the TV in the home through other terminals, and all this, you do not need to understand the highly technical!
      Key Features:
      1, for the (high-resolution) large screen device designed to provide a more delicate UI effects and interaction easier file management;
      2, supports a variety of file-based operations, perfectly adapted to a variety of actions, including the TV remote control;
      3, from the "experience of God" view, use bright color concise layout, provides a clearer classification of file operations, file information show, maximize the efficiency of document management;
      4, using the new file handling, faster than 40% above the normal way, it can be faster to open, edit files.
      Main features:
      1, intelligent document classification, white filers can identify the terminal (mobile device) installation files, image files, video files and classify them, you can see directly in the document classification, without the need to enter the Find the folder;
      2, Additional file information display for the selected folders and files will show the appropriate file information, such as for the apk file, TV file manager will recognize the name of the program installation file, and when selected, will display the file in detail The file name;
      3, the perfect support DLNA, SMB, you can directly open to use DLNA, the SMB protocol to share files, such as installing TV file manager on the TV to turn on the computer, media files on the route, including, movies, music, pictures, etc;
      4, intelligent (for ftp server) share, a key set up file sharing (remote management), so that other terminals in the LAN, for example, mobile phone, tablet, other television access shared (including mobile devices plugged) file;
      5, open the associated support files, open media files, music files, image files, etc., will be prompted to open the way to support the association set up, and will not open the associated conflict and systems;
      6, supports thumbnails for image files, directly and display thumbnails, video document, the interception of video images as thumbnails;
      7, support for anonymous access shared files, shared for encryption, support account login;
      8. Support batch file operations, including, delete, rename, copy, cut, paste, etc.;
      9, supports common file formats, and provide the appropriate icon (icon) display, easy to identify;
      10, built-in multi-language support.
      Supported formats:
      Document Format: offic (doc, docx; xls, xlsx; ppt, pptx); wps series; txt; html, xhtml;
      Media formats: mp3, avi, mkv, flv, mwv, mp4
      Locating The Apps At Google+!
      All of my Leanback Launcher apps on Google + are located in one place under "ALL POST" go to "LeanBack Launcher Code Apps Bank" ..! You can scroll down through the apps and pick the ones you want to install on your device.
      Download Here https://plus.google.com/communities/...artnerid=gplp0 !
      PLEASE NOTE: MY ANDROID TV APPS WORKS WITH JUST ABOUT ALL ANDROID TV BOXES, BACKWARD/CROSS READY COMPATIBLE WITH CHINESE MADE ANDROID TV BOXES ALSO, RK3188/RK3288 {No Install Error Message}!
        THE BEST IPTV ANDROID APP EVER CREATED {Works With ALL Android TV Boxes}
        IPTV STALKER APP {LeanBack Launcher Code} THE BEST IPTV ANDROID APP EVER CREATED
        Give this app a serious look and test run, works like a charm on just about ALL Android TV Boxes, including the Nexus TV Player, SHIELD TV Box, Razor Forge TV Box
        and The ADT-1! The word on the streets, this app maybe going for $100.00 a year and it would be well worth it too. Give it a test run, you will love this app, it will blow your mind!
          NEWLY RELEASED Netflix API 22 build 2.2.1-643 get it at the link below
          NEW Ivue TV Guide color icons, EPG {Electronic Program Guide} built-IN Streaming multi addon selections choice, WORKS ON JUST ABOUT ALL ANDROID TV BOXES!
          ]Download Here https://plus.google.com/communities/...artnerid=gplp0 !
            {By Popular Demand} HOT! HOT! HOT, WORKS WITH JUST ABOUT ALL ANDROID TV BOXES!
            NASA APP {NASA TELEVISION} IN HD {HiDef}, See Vivid Photos Of The Planet Pluto
              SUPER MARIO BROS. 1-3 ALL Worlds {WORKS ON JUST ABOUT ALL ANDROID TV BOXES}
                Flimo {Fo} Vimeo TV ALL Videos In HD {HiDef}, WORKS ON JUST ABOUT ALL ANDROID TV BOXES
                PLEASENOTE:
                Go to the Settings > Stream video in HD, set to "on any connection", if you are using SHIELD Android TV Console,
                Razor Forge TV, ADT-1 ...
                If you are using the Nexus TV Player, set to "When connected to Wi-Fi" ...
                Features
                Flimo HD (Beta) is a Vimeo app that will allow you to browse and watch videos in HD from Vimeo.
                Some of the app features include:
                * Watch videos in HD or SD from Vimeo
                * Chromecast support
                * Search for Videos/Channels/Users
                * The ability to like and comment on videos
                * Follow your favourite channels and users
                * Log in to view your Vimeo feed
                * Log in to access your “watch later” list
                * Add videos to your “watch later” list easily and view them later using the app or the Vimeo website
                * Share videos easily
                  {You Asked For It}, Works On Just About All Android TV boxes!
                  Kodi 15.2 Data Master Media Wizard NOW WITH JARVIS v16.0 SPLASH SCREEN!
                  Download Here https://plus.google.com/communities/...20500984874818 !
                    Should Work On Just About All Android TV Boxes
                    YOUTUBE TV GAMING APP IN HD {HiDef}, {Side Loading Required}, {FULL ANDROID NOT REQUIRED}!
                      {Games Knows Game}
                      VELOCITY {Now On The GAMES LeanBack Launcher} Enhanced Intergalactic Graphics!
                      All Android TV Box Owners Will Love This Game, Give It A Test Run {A OUYA GAME} A Game Controller Is Required!
                        ty so much
                        My tv box is jesurun cs968 rk3188 and your Rom is really perfect for it.
                          Showbox Apk is a great app to watch any favourite movie or TV show on your Android device. With showbox amazing features and easy user interface, showbox download has gained much popularity among its users and is probably the best answer to most of their problems at www.showboxapkdownload.org
                          Showbox Apk Download or Showbox App Download Guide. Check Showbox for PC , Showbox for iPad and show box for Android Download Free
                            NFL Network, "{NFL REDZONE}" NFL Fantasy
                            NFL GAME PASS APK {LeanBack Launcher Code Built In}, NFL Account Required!
                              Now On The LeanBack Launcher, The Ultimate NFL Multi Media Sports App & More
                              ]HOT! HOT! HOT, THE REAL DEAL
                              NFL MOBILE 2015 {ALL-IN-ONE}
                              PLEASE NOTE: "{NFLNOW FREE$$$ STREAMING 24/7}", PLAYBACK HIGHLIGHTS, STOTIES, STATS, NOTIFICATIONS & MORE
                              PLEASE NOTE: NFL GAMEPASS REQUIRES A LOGIN ACCESS ACCOUNT AND WATCH THE GAME OF YOUR CHOICE!
                              ALL NEW for the 2015 season, NFL Mobile is the best, pure football app for any fan. The redesign of the Official NFL app brings fans a different experience depending on the day and time. Whether it’s in season or off season, game day or non-game day, NFL Mobile provides fans exactly what they’re looking for, wherever they are. NFL Mobile keeps fans on top of the game with breaking NFL news, up-to-minute scoring, in-game highlights, live videos and more.
                              NFL Mobile Features:
                              • STORIES: Read articles and watch videos highlighting the latest stories and breaking news from around the NFL and from all 32 teams
                              • GAMES: Follow along with up-to-the-minute scoring, in-game highlights, big play markers and a redesigned drive chart
                              • STATS: Track league and team leaders in all major stats categories
                              • MORE: Watch video on demand, see the NFL Network schedule, browse the NFL Shop store, and more
                              Only on Verizon:
                              Verizon customers are eligible to access exclusive live video on their phone*
                              Included during the Preseason:
                              • Nationally broadcast games on CBS, ESPN, FOX and NBC
                              • Games on NFL Network
                              • NFL Network 24/7/365
                              Included during the Regular Season:
                              • All Primetime games (Thursday, Sunday, Monday Night Football)
                              • Local Sunday games broadcast in your region
                              NFL RedZone is available via additional subscription for $1.99 per
                              month. Subscription auto-renews monthly.
                              On tablet devices, NFL Network 24/7/365 and NFL RedZone are available for eligible subscribers of AT&T U-verse, Charter, Cox, DirecTV, Dish, Optimum, Verizon FiOS and many more providers.
                              All fans can access NFL Game Pass subscription content within NFL Mobile. NFL Game Pass is a subscription product with features that vary based on location. Learn more at www.NFL.com/Gamepass.
                              Learn more about the NFL’s digital offerings: nfl.com/mobile, twitter.com/nfl, and facebook.com/nfl
                              NFL Mobile allows use of AirPlay and Chromecast when viewing all video-on-demand and select live content, including all content within the NFL Game Pass offering. However, NFL Mobile does not permit outputs from phones of live games, NFL RedZone or NFL Network to external displays via HDMI, Chromecast, AirPlay, Miracast or other similar streaming functionality due to rights restrictions.
                              * Data usage applies for app download and use.
                              Live streams of Preseason games airing live on NFL Network will be blacked out in any market in which the game is broadcast locally.
                              Local CBS and FOX games vary based on your current geographic location. The games available will match the television listings of local cable providers in the region where you are currently located. Location information is required to provide live local CBS and FOX games.
                                You should really try Showbox apk for your Android Smartphone and Tablet. The Showbox app allows you to watch Live TV and you favorite Movies on a Go. Must Try it
