Awesome work by the way, ignore the trolls. You dont see them devoting their time to anything useful ?
ULTRA 1080p Showbox/Video Mix CR11S/CS968 Multi-Media Super ROM AP6210 LIVE TV/SPORTS 24/7, {WORLD CUP APP READY}
Hey Tech1, I've loaded this rom. Everything works perfect except for 1080 movies I've got the cs968 with the 2mp camera built in. Is there something else i should be doing ? BTW im using beyond xbmc to play my movies. Smaller movies seem to work fine. Tried local and network with the same result.
Originally posted by ausratty View PostHey Tech1, I've loaded this rom. Everything works perfect except for 1080 movies I've got the cs968 with the 2mp camera built in. Is there something else i should be doing ? BTW im using beyond xbmc to play my movies. Smaller movies seem to work fine. Tried local and network with the same result.
Originally posted by ausratty View PostHi mate thanks for the reply. They play perfect in mx player.
I tried changing the player to mx player in xbmc however it says it wont do it for network ?
Thanks again
Directions on how it works with the MXPlayer, on the movie start up pressing the "C" key on your keyboard or back side remote keyboard ... A pop up menu will appear, just follow the on screen options, enjoy ...
ok i've just reinstalled everything thinking im doing something wrong. Started from scratch with your latest rom 9999 and uninstalled mxplayer and beyond xbmc then reinstalled the versions as specified. However when i click c on the item and go to play with it just says mxplayer (local only) it wont play the movies. Sorry to be a pest.
Originally posted by ausratty View Postok i've just reinstalled everything thinking im doing something wrong. Started from scratch with your latest rom 9999 and uninstalled mxplayer and beyond xbmc then reinstalled the versions as specified. However when i click c on the item and go to play with it just says mxplayer (local only) it wont play the movies. Sorry to be a pest.
Originally posted by ausratty View PostThanks mate, i didnt have pro installed. I ended up deleting beyond xbmc and installed the latest gotham 13.1 Works perfectly.
However now i seem to have a flakey wifi. Same on 2 boxes. trying to work that out now.
You want a Android TV box, that will give you the most TV entertainment, that's what it's all about and the reason why you purchased the box in the first place, enjoy have fun ...
There are currently 1847 users online. 1 members and 1846 guests.
