SD Card booting without flashing your device
    Originally posted by linuxium View Post
    Thanks a lot Ian ! I will try this one.
    I have to say, in the end things are not so perfect with my MK809III / QC802.
    I'm in trouble with the wifi. Sometime it disappears. I will play a little more and i'll come back to report some conclusions.
    Cheers.
      Cheers.
      My wifi never worked and I am still working on it. Mine is the RTL8723BS chip on it and it is a bugger finding a driver or anything to get it to work.
      Also have something here for those who want to change there resolutions to a size that might not be supported. Found it the other day but can not for the life of me remember where. Not mine but helped me out big time.. It will let you change the resolution to whatever your monitor size it. So hope this helps;
      sudo -i
      cd /etc/X11
      touch xorg.conf
      nano xorg.conf
      then in the simple nano editor, write (or just paste) this:
      Section "Device"
      Identifier "Configured Video Device"
      EndSection
      Section "Monitor"
      Identifier "Configured Monitor"
      EndSection
      Section "Screen"
      Identifier "Default Screen"
      Monitor "Configured Monitor"
      Device "Configured Video Device"
      SubSection "Display"
      Modes "1280x800"
      EndSubSection
      EndSection
      then save the file using Ctrl+O, then quit Ctrl+x;
      Voila - logout and login again and resolution is fixed forever;
      In the above "Modes", you can put in whatever monitor resolution you want. Mine is currently 1280x1024. Hope that helped. Thanks.
        Too bad, i just remade my sdcard with Ian 720p kernel...
        There is a way to make an image of a "ready to boot" sdcard ? I have just 1 working sdcard and when i play with kernels or rfs i have to setup again everything in Ubuntu when i want to come back to an older config.
          I have a question. The install of Linux that I am currently running on the 809iii is ubuntu 12.04 but I hate the unity desktop. Is there other versions I can be running instead of this one? This one, like I said, gives me a desktop, that I hate, but I would like to try another flavour or different configuration, like LXDE or even XFCE. Where do I get those to give me a new desktop? Thanks again.
            Current status:
            WHO DEVICE STATUS CONFIRMED
            marcelv T428 Unknown Pending
            Boocy Unknown Unknown Pending
            no_spam_for_me Unknown Unknown Pending
            knawnd Minix Neo x7 Unknown Pending
            AudioBubble MK809III/QC802 Working Confirmed
            thafath MK802IV Working Pending
            sudros MK809III Not working Pending
            Mine (MK802IV) is definitively working great, wifi included. I did update, and upgrade. I have to say that I got wifi to work using the command line (or if you can try wicd) not possible with the included network manager. Thank you again Ian.
              You can install several desktop environments in ubuntu. Here's a tuto but it's in french... I guess you can find same tutos in your native language.
              If you swap for an other distro you also change all the packages. Personally i don't really like the Unity desktop but i much prefer the packages in Ubuntu than those installed with Lubuntu or Xubuntu.
              But if you want to switch to another distro, you can keep your kernel.img file and change the rootfs.img file. You will find rootfs for Lubuntu and Xubuntu in this thread :
              Thanks Ian again !
                Have you tried to search on the web? I got a lot of links with info on switching Unity to XFCE just by searching on "switch unity to xfce". E.g. that one.
                  One of the possible way.
                    Thanks Ian again !
                    I tried the Lubuntu and xubuntu from there but they did not work. Think I have to change the SD card size to allow them to fit.
                      I will try, thanks.
                        How do you do that ? You can't boot ?
                        Don't work if you remane the rootfs file as rootfs.img, you place it in the folder with the other files (kernel.img, boot.img, parameter.img, sdboot_rk3188.img and create-sdcard) and launch create-sdcard ?
                          Another quick question, but can this ARM processor run a normal 32 bit version of Linux or does it have to be ARM based? Thanks.
                            They were both over 2 gigs in size and the sd card was only reading 2 gigs of space. Nothing copied over. No idea why it will not show the full 8 gigs of storage on the card.
                              Check your sdcard with Disk Utility or Gparted or something else regarding your OS, erase all the partition and create a new one.
                                it's because rootfs.img has 2GB size. In Ian's post it's written:
                                Don't forget to first enter 'sudo resize2fs /dev/mmcblk0p1' afer logging in so that the file system can use the entire SD card.
