My MK809III (kind of) is absolutely bricked and I don't think that it's NAND will ever see some new firmware again. Pretty much my TV player went through the same process as described here:
So, the changes of having some Android version running again on my dongle are very slim, unless there's a way of making a compatible FW version running from SD card.
So far I have only partial success.
The NAND based FW I usually installed to have my device working properly was the
MK809III_update_dongle RK3188T 6210_3.1 However, when installed by SD card using the SD Firmware Tool it doesn't boot.
I can run Ubuntu based on Linuxium's Rikomagic MK802IV New (AP6210) - https://drive.google.com/file/d/0B99...mIyLTl4Z3ZFRmc WiFi working ok
I can run radxa_rock_android_kitkat_r2_140911 SDCard version but not the NAND version
however wifi and bluetooth are not working. I guess their board does not use a AP6210 Chipset.
I made a binary comparison between these two radxa distributions and they are exactly the same except for the kernel. both kernels have the same size but their content is different. One boots correctly from SD Card and the other doesn't.
So, Boocy must be right. The trick is in the way the kernel is compiled.
I would be happy if someone could do the same trick with a kernel with suport for AP6210 so I can have a usable android installation with Wifi working properly...
I'm trying to lean how to cook such kernel, but so far the challenge has been way too big for my SW Development habilities
Can someone help with this?
