1. Get the Radxa rock package by Ian. The Radxa Rock boot image is compatible with MK908v5.
2. Get the finless ROM 1.7a for MK908 and unzip the file.
3. Replace kernel.img in Ian's package with kernel720vsync.img (from Finless ROM). Rename the file to kernel.img
4. Insert an sd card in your Linux PC and run ./create_sdcard
5. You will get an SD card that works with MK908v5.
There is no need to flash the MK908. Just insert the sd card and enjoy.
Best regards,
Anat
