- added localation setting
- 8gb in one partition
- fixed a bug in hardware keyboard setting
- google apps updated
- several fixes which i don't remember
- wasser xbmc 1.2
- improved hdmi driver, system stability
download: http://www.freak-tab.de/wasser/wasse...mini-1.0.4.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.3.apk
version 1.0.3a
- included all features/fixes from 1.0.3
- fixed critical permission issue for external/internal storage
- fixed usb port issue
- added google voice support
firmware for new revision: wasser-firmware-minix-x7-mini-1.0.3a.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.2.apk
please use RKBatchTool to flash the new firmware
version 1.0.3
- based on kikat 4.4.2
- built from sources
- perfect 1080p fullhd video streaming
- multiuser support
- preload wasser xbmc-1.1 based on gotham 13.1 stable release
- passthrough support in wasser xbmc
- busybox up to date
- google apps up to date
- screen rotation support
- reboot/sleep/bootloader mode dialog
- full support stock ir remote
- lock screen support
- init.d support
- A2 Airmouse support
- cwm recovery support
- ntfs, nfs, cifs, hfsplus filesystem support
- rooted
- usb webcam support
- wifi support
- ethernet support
- bluetooth support
- enable tun in the kernel
- add setting for Accessibility
- add setting for sleep, daydream and wallpaper
- add support for Mouse Wheel Zoom Settings
- add support for no wakup on mouse movement, enable it by default
- add manual hide system bar, you can wipe from bottom/top of screen to show it again
- add setting for Alarm/Notifications volume
- add support hls streaming
- fixed red frame issue in chrome browser
- added option to disable the hardware keyboard (add ro.hardkeyboard.support=false to
/system/build.prop to disable hardware keyboard )
firmware for new revision: wasser-firmware-minix-x7-mini-1.0.3.zip
