NEW - Minix X7 Mini - wasser firmware 1.0.4 - KiKat 4.4.2
Originally posted by Taggarts View PostHi just installed worked great so far, but I can install sporting stream addon dependencies not met?? Thanks
Force refresh repository which serves sporting stream add on
Wait 3-5 mins then try installing add on again
No joy?
Restart xbmc and wait 3-5 mins then try installing the add on again.
If that don't work google your problem, the repo/add on might be broken/downMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
No joy?
edit ive sorted it now lol thanksLast edited by Taggarts; 22 August 2014, 12:51.
Sound Dropout in Wasser XBMC
I have Wasser ROM + Wasser XBMC which plays 1080p movies over the network so smoothly where I had issues with other ROMs and other XMBC versions.
However, when playing movies with DD or DTS with passthrough to the receiver, i am experiencing sound dropouts every 2-3 minutes for a fraction of a second.
When in play DD audio, the dropout is less frequent, but with DTS it comes at every 2-3 minutes.
Anyone out there with any solution to this?
Thanks in advance.
Passthrough
I have been using this Minix Neo X7 for a while now with several roms and found wasser is the most stable than all others including stock rom. I have never setup passthrough and would like some help. Should I just set it up with XBMC or from the Android Sound menu?
I recently purchased Sony STR-DN1050 with a 3.1 system.
I do a lot of youtube streaming and would like to get 3.1 audio from there aswell rather than sterio
thanks
Setup Passthrough
Originally posted by vic_singh View PostI have been using this Minix Neo X7 for a while now with several roms and found wasser is the most stable than all others including stock rom. I have never setup passthrough and would like some help. Should I just set it up with XBMC or from the Android Sound menu?
thanks
Second, setup assthrough in XBMC
Do this, and you will have DD & DTS passed to your receiver as digital signal (without processing)
There are currently 1337 users online. 1 members and 1336 guests.
