DEL
NEW - Minix X7 Mini - wasser firmware 1.0.4 - KiKat 4.4.2
Originally posted by arhim View Postfirmware 1.0.4
2 crashes due i have been installed applications - at 6th or 7th application, that i installed direct from internal space - first reboot
second reboot was during applications updates via Google Play
it must be wrong with your device, or bad flash
wasser
Hello guys,
I'm trying to mount automatically my nas on this ROM but it's not working. Impossible to mount my nas.
I added file 90SMB in /system/etc/init.d with this command:
busybox mount -t cifs -o user=****,password=****** //192.168.0.11/Music /mnt/Music
It was working with quickshot V3...
I miss something?Thanks for your help.
Mouse long-left-click not working in XBMC
Hi Wasser,
Thank you for an excellent ROM for the X7 Mini.
One thing that was missed out from the previous XBMC is the mouse left-long-click menu activation.
It was there in the XBMC that came with the 1.03 version.
It is not there in the new one.
Can you fix it and post a re-compiled XBMC?
Thanks,
Originally posted by wasser View Postversion 1.0.4- included all features/fixes from previous release
- added localation setting
- 8gb in one partition
- fixed a bug in hardware keyboard setting
- google apps updated
- several fixes which i don't remember
- wasser xbmc 1.2
- improved hdmi driver, system stability
I have a few questions:
1. Do Tincore Keymapper app working properly. - On the original rom could not calibrate the screen.
Is Google Play Music app working properly? On the original rom playing songs stops after one song.
How much memory is allocated to applications. Is it possible to install applications on the memory card?
And one last question:
Which button should i use to flash firmware in RKTool? Upgrade or Restore?
Originally posted by TVDroid View PostWith the 1.0.4 the xbmc dont work with my Mouse ??
Can you please share the XBMC apk from the 1.0.3a ROM ?
Thanks my Friend !
Settings->System->Input devices->Enable mouse and touch screen support
wasser
Menubar at the bottem
First of all installerd your Rom and it works great so far. Interesting rom update with Windows 8.1 finaly works with the kitkat devices.
Only one anoying problem, the menu bar at the bottem. I'am missing the auto hide feature. can't seem to find it in the menu.
DTS sound with wasser XBMC solved for me by setting advanced sound options and selecting "receiver capable of DTS"
Thanx for the great work
There are currently 1343 users online. 1 members and 1342 guests.
