NEW - Minix X7 Mini - wasser firmware 1.0.4 - KiKat 4.4.2
Sound Dropout
Originally posted by drjf View PostHi,
I have Wasser ROM + Wasser XBMC which plays 1080p movies over the network so smoothly where I had issues with other ROMs and other XMBC versions.
However, when playing movies with DD or DTS with passthrough to the receiver, i am experiencing sound dropouts every 2-3 minutes for a fraction of a second.
When in play DD audio, the dropout is less frequent, but with DTS it comes at every 2-3 minutes.
Anyone out there with any solution to this?
Thanks in advance.
Originally posted by drjf View PostNo one with a solution? or nobody cares?T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
Going back to JB
Love the rom, but now that Amazon instant video has been opened up to all android, I am going to go back down to 4.2.2 since it seems that 4.4 Minix roms don't play nice with it. Just to confirm I will need to delete the bootloader and reinstall it as described by this post
Before I reinstall a JB rom?
Originally posted by wasser View Postversion 1.0.4- included all features/fixes from previous release
- added localation setting
- 8gb in one partition
- fixed a bug in hardware keyboard setting
- google apps updated
- several fixes which i don't remember
- wasser xbmc 1.2
- improved hdmi driver, system stability
download: http://www.freak-tab.de/wasser/wasse...mini-1.0.4.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.3.apk
version 1.0.3a
- included all features/fixes from 1.0.3
- fixed critical permission issue for external/internal storage
- fixed usb port issue
- added google voice support
firmware for new revision: wasser-firmware-minix-x7-mini-1.0.3a.zip
wasser xbmc: http://www.freak-tab.de/wasser/wasser-xbmc-v1.2.apk
please use RKBatchTool to flash the new firmware
version 1.0.3
- based on kikat 4.4.2
- built from sources
- perfect 1080p fullhd video streaming
- multiuser support
- preload wasser xbmc-1.1 based on gotham 13.1 stable release
- passthrough support in wasser xbmc
- busybox up to date
- google apps up to date
- screen rotation support
- reboot/sleep/bootloader mode dialog
- full support stock ir remote
- lock screen support
- init.d support
- A2 Airmouse support
- cwm recovery support
- ntfs, nfs, cifs, hfsplus filesystem support
- rooted
- usb webcam support
- wifi support
- ethernet support
- bluetooth support
- enable tun in the kernel
- add setting for Accessibility
- add setting for sleep, daydream and wallpaper
- add support for Mouse Wheel Zoom Settings
- add support for no wakup on mouse movement, enable it by default
- add manual hide system bar, you can wipe from bottom/top of screen to show it again
- add setting for Alarm/Notifications volume
- add support hls streaming
- fixed red frame issue in chrome browser
- added option to disable the hardware keyboard (add ro.hardkeyboard.support=false to
/system/build.prop to disable hardware keyboard )
firmware for new revision: wasser-firmware-minix-x7-mini-1.0.3.zip
Sound Dropout
Originally posted by Sarco View PostI do not have your anoying problem but maybe just maybe you should look at your installed app. I experienced xbmc to slow down and exit when mail noticel popup. To avoid such behavior I simply remove the mail notice from app. Do you have an app who may do something every two or three minutes?
with Wasser XBMC, it happens every 3-4 minutes or so..
- wasser xbmc 1.2
is this ROM compatible with AP6210 devices? (CS968)
i tried a few roms back and forth between minix x7 and cs968 of which some worked great!!
regardless...thank you for your work
Originally posted by drjf View PostI had the same issue with wasser xbmc but not with SPMC ..the sound dropout issue went away...
I ask because I am still on Quickshot V3.1 with Beyond XBMC, and don't feel like investing the time flashing and setting up everything if it is not worth the trouble. My experience with the setup I now have is that the DTS audio quality is not up to that of my 4 year old WDTV Live, and no version of Android XBMC I have tried will play many of the blu-ray movie rips I have without re-muxing. So I guess I'm trying to determine if the setup you now have is the current state of the art for the X7 Mini before spending time on it.
Originally posted by drjf View PostYes..
I have tried almost all combinations..
Now stuck with Wasser ROM and SPMC which runs 1080p over the network (ethernet, not wifi) without a glitch..
The new kodi with passthrough also works flawlessly with this ROM but many add ons are faulty...
Originally posted by pennhaven View PostThank you. I will plan to give it a try. I have ether-net. Don't use many add-ons.
There are currently 1341 users online. 1 members and 1340 guests.
