So while still learning stuff on AML this 1.7 ROM took a little more time.
I have new features and fixes in 1.7 I had not done before
This is based on the S82/S89 105K4 ROM.
This is for the following devices:
- Tronsmart S89 and S89-H
- Beelink S82 and S82-H
- Beelink M8. Well 105K4 says it's for the M8 but I do not have a M8 to test so I am not sure.
This IS NOT for the ENY/Acemax EM8 square box!!!
____________________________________
Features and release notes for my 1.7 ROM:
1) Properly rooted using SuperSU. What does properly mean?
2) Updated Google framework and Play Store core files. The ones in the stock ROM were out of date.
On first boot NOTHING will need to be updated once you logon to Google Play. That is as of this date.
3) Debloated of junk APPs and Google Apps you can get from Google Play.
I did remove XBMC and other pre-install APPs as well. I like a CLEAN ROM that you the user can setup the way you want. Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer). If you want the original XBMC APP then download it from Geekbuying.com
4) As always, full init.d support! If you do not know what that is... ignore it.
For geeks that want to use it. It is there!
5) I fixed the AOSP Launcher3 for several things:
- Removed the Google search bar by request.
- Added more than one screen for scrolling.
- Updated the dock icons to things more useful.
- Apps installed with Google Play will automatically be added to the home screen.
I think you will like this launcher better
6) Fix the bottom navigation bar.
There was a bug in 105K in that on first boot the navigation bar is seen and it is stuck there, even though in Mbox Settings it is set to hide the navigation bar! Before this fix you had to go into Mbox settings>screen and toggle hide bar off and back on to make it work.
This is now fixed. It is hidden per the default Mbox settings on boot.
7) By request I added the calendar APP and it now syncs with your Google account.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
This should also allow Netflix HD but I have not tested it.
Your device will show up in google play as Nexus 10 device not a S82/S89! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES File Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a S82/S89.
9) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
10) Carrier spoofs for better APP compatibility.
11) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
12) Added bonus! CPU fixer patches!
In this ZIP is a CPU fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor.
See the README.txt in that folder for an explanation and how to install them.
________________________________________________
OK so here is the download!
READ the README.TXT in the zip for instructions!
ROM -> Tronsmart S89 / Beelink S82 & M8 - Finless ROM 1.7 (349 megs)
