Beelink S82 & M8 / Tronsmart S89 - Finless 1.7 ROM
    there are many apps in the play store that can do this. Root and restart required
    @µ$ł!Ω
      720P patch
      OK I have solved the issue with 720P and locking the Android system to 1080P when in 720P mode.
      I will have a patcher for you guys today.
      However you must understand what the issue is with switching resolutions in Android on the fly! It canot be done that I know of and this is what Beelink is trying to work around. When I post the patcher ZIP I will explain what this issue is and why.
      Needless to say in order for Android to know whats what, a reboot is required when switching between 720P and 1080P.
      This is why even on RockChip ROMs, to get true 720P or true 1080P you must flash a new kernel with a different lcd_density setting which causes you to reboot to do it. AML allows HDMI switching on the fly unfortunately Android cant deal with that well. It was not designed to out of the box.
      Anyway I have a fix for you 720P TV people.
        720P patch is posted
        OK patch ZIP is posted.
          Does this mean that playing a 720p media file after playing a 1080p one will require a reboot to display properly and fill the screen on my 1080p tv?
            no don't use the patch if you have a 1080p tv resolution unless for some reason you wish to be able to change to 720p on your 1080p tv for some reason. Oman did a resolution lock on 105k4 for 1080.
            @µ$ł!Ω
              Hi.
              MY TV supporting the 1080P. but i see movies as 720P also.
              do i need the patch or the original file?
                No, you don't
                Sent from my GT-I9300 using Tapatalk
                  I have experienced play store not loading on 104k4 rom aswell, i found it was my a/c plug had bad connection, so i was loosing time and date settings, so on first boot google has a dummy spit as it sees incorrect time and date.
                  time and date are probably resetting after flashing?? so, make sure time and date are ok, then force stop google play and then reload it.. ( works in my case )
                  PS Bob , great work on new rom, i see one of the fixes is being able to synch google calender, what was the actual cause for this, as it was doing my head in wondering why i couldn't synch it on 104k4...
                  cheers
                  Addy
                  Sent from my Commodore 64 using Geos
                  My devices:
                  Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
                  Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
                  Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
                  HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
                    I think it would need to be spoofing a nexus 7 and not a nexus 10 to get hd in netflix, i tried using an app to spoof nexus 7 but i think it only works for the play store, netflix still thought it was a nexus 10
                    Tronsmart Vega S89 Elite Amlogic S802 with finless2.0
                    Tronsmart Draco AW80 Meta Allwinner A80 Octa Core finless1.0
                      If your tv is 1080 don't worry about the patch. Its only for tv resolutions (not "video resoltions") that are 720. Its basically your android default system resolution. You can watch any resolution on a 1080p tv that is 1080 and under. Exapmle: watching a dvd or vhs on a 1080p tv.
                      @µ$ł!Ω
                        Originally posted by korenspeed View Post
                        Hi.
                        No, you don't need to patch you system because your video player / the box do an "upscale" to 1080 ...
                        (I don't know if maybe xbmc with the correct settings will be able to temporary switch, but I don't use somthing like that, so I don't know)
                        RK3288 Devices
                        - Overview BOX (LINK !)
                          Fix for box turn on and off?
                          Does this firmware fix the Tronsmart S89 box turning on and off all by itself when in standby?
                            Originally posted by gstar2 View Post
                            No, but aint that sorted by turning off sync in the account settings?
                              This is for the following devices:
                              - Tronsmart S89 and S89-H
                              - Beelink S82 and S82-H
                              - Beelink M8 square box. Well 105K4 says it's for the M8 but I do not have a M8 to test so I am not sure.
                              This IS NOT for the ENY/Acemax EM8 square box!!!
                              Bob please correct your 1st post. This firmware is for the following Beelinks:
                              - M8 round box
                              - S82 round box
                              Beelink does not have an S82-H version yet nor a square box with S802/S802-H
                                @µ$ł!Ω
