S802 Xbox support installer
    Originally posted by hansxia View Post
    Hi MG, I had test a usb buletooh adapter, with cambridge silicon radio chip, vid0A12&pid0001, but is dosn't work .
    your game support ko are all GOOD! thank you.
    Try with more general and little bit old model of bluetooth dongle. That would be supported by kernel I think.
    Regards,
      DO NOT DOWNLOAD THIS FILE, THIS IS NOT USABLE FOR OTHERS!!!!
      Bob,
      Attached files are modified boot.img by myself, would you please make flashable zip for me?
      What are the different from existing boot.img?
      - using new released source from AMLogic web site (18/06/14)
      - using unified configuration from s82,em8,x8h.(it would be include hid drivers)
      - add xpad support, nfsv1,2,3 support, native NTFS support
      Why size is smaller than existing one even add more modules?
      - S82 boot.img have a BIG mali.ko (3.6MB), but new mali.ko is about 250KB as like em8 and x8h.
      What is diffrent between s82_1_boot.img and s82_2_boot.img?
      - s82_1 use extracted device tree file from existing boot.img
      - s82_2 use default device tree from kernel(meson8_skt).
      Thanks,
      MG.
      PS] Maybe I need open new thread for this?
        Originally posted by cuezaireekaa View Post
        can you tell us where you put these two files for ps3 controller support? and what permissions? 644? tia
        ☆sent from a finless bob rom powered MINIX X8h android tvbox w/tapatalk☆
        You need to copy both .ko files to system\lib
        You then need to modify the properties of those 2 files to be r,w,r,r - i used a program called es file explorer for both the copying of the files and changing of file properties. Make sure es file explorer has root manager set to 'on' first.
        I then used android terminal emulator to insmod the files. Make sure terminal emulator has superuser access.
        Controller worked fine after that.
          Originally posted by firestorm2yk View Post
          Tested wireless ps3 controller on em8 square box and it works great!
          Both wired and wireless works! No sixaxis controller app needed for wireless, it works with the normal Bluetooth!
          Well done MG!
          P.s - you need to get yourself a donate link as I would totally donate for all your hard work!
          have you got wired and wireless xbox 360 w/adapter working on the EM8 yet? I tried the xbox patches but my wireless 360 controller wont pickup and I dont have a wired 360 or any PS3 controllers to try. I am using lifeforce rom(3.10.33 kernal, based off the Acemax 5/12 rom) which has init.d support.
            Am using finless 1.7 and wired and wireless xbox 360 controllers work fine except for the dpad on the wireless one - but im starting to think that's more of an app issue.
              Any app will show the entire d-pad as "null" or register it as one key - which I assume is pretty much the same thing at the app level.
              There are apps that support the d-pad. USB BT Joystick Center and I think Snes9x work. Maybe even Mupen64AE. But I think these apps specifically support the (wireless) xbox controller - by bringing their own driver, I guess.
              So I don't think it's an app issue after all, although apps can make it work. It must be possible to receive regular D-Pad input from the controller. Strangely, it's pretty hard to find information about all this. I've seen a couple of guys trying different keylayout files, but it wouldn't work for me
                Well done MG!
                Would you please describe the procedure for me?
                1. Did you installed the xpad patch before hid-sony?
                2. Did you matching the BT address with device?
                3. Did you setup connection with wired first and then try to wireless?
                Everybody have different behaviour so I want to make clear step for connection.
                Thanks,
                MG.
                  Originally posted by woomg View Post
                  Bob,
                  Thanks,
                  MG.
                  Woomg, here is your boots made flashable.
                  Download and unzip it. In it you will find the 2 boot zips you put on SDcard and flash.
                    OK I am trying to catch up but cannot follow what went on.
                    What do you guys need made into flashable zips?
                      UPDATE - new ZIPs available which add the PS3 KO modules
                      OK folks, I updated the first post here with new download links.
                      The ZIPs now install needed KO modules for your specific box/ROM
                      They now also install the XBOX KO and PS3 KO modules.
                        Thanks Woomg and Bob now we should have support for the ps3 controller also time for testing
                          does the zip for the M8 work with lifeforce rom and if not could you create one for it? I installed the M8 zip but I cant get my xbox 360 controller to work. Im using it with the xbox wireless receiver adapter.
                            Your going to have to ask LifeForce.
                              Originally posted by trebor View Post
                              Thanks MG
                              Tried modify init.d etc...no go... not much knowledge
                              But
                              insmod /storage/emulated/0/download/ etc Did work.....
                              Using PS3 gamepad with usb cable in Asphalt 8
                              Such confusing commands (to me) nothing like DOS...no dir no /? for help goodness will have to do some more reading about this language of Android
                              Again thanks for your help
                              Update
                              Rechecked and double checked the modify init.d Oops spelting errors all fixed
                              reboot lsmod showing the goods.
                              ENY MX Square box
                              Rob
                              Further update 25/06
                              Now I have a wired 360 Controller and works well testing on asphalt 8.
                              PS3 Controller works well wired.
                              Trouble getting PS3 bt to sync, tried with the 6 axis apk from Google find its, get the address changes etc but will not to the final sync often get a Segmentation fault ?.
                              Any tips to get it working appreciated,
                              Rob
                              Update
                              Using the very old Xbox controller and a usb/convert plug http://www.****.com.au/itm/121082262...84.m1439.l2649
                              Controller also appears to perform well.
                                Thank you very much, Bob.
                                However, I just heard about new 106K04 will be released in really soon.
