http://www.****.de/itm/USB-Drahtlos-...item258ce14624
S802 Xbox support installer
Originally posted by zektor View Post
http://www.****.de/itm/USB-Drahtlos-...item258ce14624RK3288 Devices
- Overview BOX (LINK !)
Yes, I bought the XBOX360 controller + receiver initially for my PC playing the forthcoming Assassin's Creed Unity, not having a XBox at all. The HardwareGuru 1.8 Custom Rom works perfectly on my Neo X8-H + UPDATE ->Xbox KO module installer for STOCK Neo X8 ROMs (200 KB)
IT WORKS!!!
Originally posted by woomg View PostHi,
After comparing kernel configuration between each boxes, I found almost HID drivers are removed from ENY-M8 and X8-H boxes.
So, I just compiled two drivers for sony devices.
hid-ps3remote.ko : PS3 BD RemoteControl driver
hid-sony.ko : PS3 Controller driver
I'm not sure it will works or not, please test this drivers and let me know about result.
Thanks,
MG
Both wired and wireless works! No sixaxis controller app needed for wireless, it works with the normal Bluetooth!
Well done MG!
P.s - you need to get yourself a donate link as I would totally donate for all your hard work!
Originally posted by firestorm2yk View PostTested wireless ps3 controller on em8 square box and it works great!
Well done MG!
All of buttons and sticks are works well?
Any other person who succeed installation?
Thanks,
MG
(i have a Tronsmart s89-H running 1.7 finless and the package from the first post of this thread)
I'm not sure how to "install" them... (I don't know much about this type of thing on android... i'm rather new to the whole android scene)
Do you install these sony "drivers" like the package on the first page of this thread or do you install them some other way...?
Please could somebody give me a step by step "guide" on how to do this...
I really want to test these with my knockoff ps3 controllers (and the real ones of course)
Thanks in advance
Originally posted by alucard369 View PostEuhm sorry for my noob question but how do you install these...?
Thanks in advance
OK tried to install the PS3 drivers from Woomg (m8_x8_hid_sony.zip) from post 90...
got a error while installing, something along these lines:
footer is wrong
error signature verification
any adea what i did wrong...? sorry for my stupidity/not knowingLast edited by alucard369; 23 June 2014, 15:18.
Re: S802 Xbox support installer
Originally posted by alucard369 View PostOK tried to install the PS3 drivers from Woomg (m8_x8_hid_sony.zip) from post 90...
footer is wrong
☆sent from a finless bob rom powered MINIX X8h android tvbox w/tapatalk☆
Originally posted by firestorm2yk View PostYep, all buttons, triggers and analog sticks register in both wired and wireless mode.
Originally posted by Dandroid534 View Postummmm, well I took the original zip, added the files, edited the code to add all those kos, and then tried to sign it...
lol it installed them then erased everything.... well, it was worth a go i guess...
if anyone know a guide of how to do this sort of thing that would be appreciated...
Many happenings at last night ( here is early morning.).
OK, it is temporary solution till Bob make new flashable file for us.
You must can use init.d, and already installed xpad modules.
1. extract my zip file and copy hid-*.ko to /sdcard/Download
2. open terminal or connect to device via ADB (or ssh)
3. run follow shell commands as su mode
insmod /sdcard/Download/hid-sony.ko
insmod /sdcard/Download/hid-ps3remote.ko
If you have more knowledge, copy *.ko into /system/lib folder and modify xpadjoy script at the /system/etc/init.d.
Best luck...
Best luck...
It Worked
Best luck...
Thanks MG
Tried modify init.d etc...no go... not much knowledge
But
insmod /storage/emulated/0/download/ etc Did work.....
Using PS3 gamepad with usb cable in Asphalt 8
Such confusing commands (to me) nothing like DOS...no dir no /? for help goodness will have to do some more reading about this language of Android
Again thanks for your help
Update
Rechecked and double checked the modify init.d Oops spelting errorsall fixed
reboot lsmod showing the goods.
ENY MX Square box
Rob
Originally posted by woomg View Posthansxia,
Attached file is set of BT drivers.
btusb.ko : Bluetooth HCI USB driver
btsdio.ko : Bluetooth HCI SDIO driver
hci_vhci.ko : Bluetooth Virtual HCI device driver
Thanks,
MG
your game support ko are all GOOD! thank you.
There are currently 4026 users online. 0 members and 4026 guests.
