Prahjister ROM 1.2 MK808(B)4.2.2 720 and 1080
    Thanks Prajister for the prompt reply
    I did a bit of research after getting my MK808b replacing the power source with below.
    Time to pull out my old power sources and do some testing
    Ed
      Swapped lead to 2nd USB socket "problem Solved"! apparently one socket is steady charge, the other is fast charge. Big thanks for fantastic rom, keep the good work on developing new roms
      Regards Ed
        1080P sound loss back!
        Argh
        Hi Prajister spoke to soon the sound loss is back. I tried a different power source then SPMC Frodo and Gotham versions, no deal.
        In the UK it is a bit of a nightmare sourcing electrical kit. The PSU judging by reviews and feedback seems to be very good. The only other weak link I see is the power cable, I have tried everywhere in the UK for a 28/24 AWG without success Ed.
          Originally posted by eddieaok View Post
          Argh
          Do you have that original short usb cable....give it a shot.....Explain your whole setup...OC or Standard kernel....720 1080 etc.
          Also try adjusting the /system/etc/cpu file down to 800 mhz instead of 1.2 ghz.... This will help to see if it is the ps...
            Hi Prajister thanks for the quick reply
            The cable is the one supplied with my stick.
            Currently I am using Shomaris 1080P O/C kernel, I also tried the 1080p kernel in your rom.
            For overclocking I have the set CPU APK running at 1.4 GHZ, also I tried 1.2 GHZ with same results. Do I access the script say using Root Manager?
            Ed
              Ed
              use es file explorer and try kernel that is no oc. Let it cool down. I found if mine overheated it took a while to get back working.
                doubt!
                hi... first of all thanks for your work... by the way... great job! I own a mk808, non b, this rom Works for me too? the tittle is confusing me!
                  Is it possible to have a cwm installable version of this 1.2 rom? Thanks
                    bump so people flash the correct one....i wish i could rename the thread
                      Found this yesterday
                        Originally posted by prahjister View Post
                        Great find!
                        I love your ROM, however I am struggling with WiFi real speed issues. I tweaked the antenna, so I usually have full range with 65Mbit, but the real speed is 1-1.5 Mbyte/s.
                        Do you have any suggestions for that? If not, can you advise me using any external WiFi adapter (maybe this one: http://www.aliexpress.com/item/RTL81...859574211.html ) ?
                          Originally posted by maludroid View Post
                          Great find!
                          If you have the ability i would get a usb to ethernet adapter. A usb adapter that has an Axis chipset works will.
                          Also try different powersupply. IT makes such a big difference. I dont have any experience with a usb wifi adapter. I would do some searching on good.
                            Sorry, I don't know what you want to say
                              Will this rom work with my original MK808?
                              I don't see anything in the thread. All references are to the mk808B.
                              Thanks in advance.
                                Thanks in advance.
                                yes rk901 as well....the title MK808(B) is supposed to mean b and not b....but i cant change it anymore. I wish i could clarify it
