Prahjister ROM 1.2 MK808(B)4.2.2 720 and 1080
Hi Prahjister!
i installed the ROM and it works fine with my stick. Thanks a lot for your effort!
But still I have some questions. Does this ROM always run on 1.2Ghz or does it slow down when apps are not running? Do i have to activate script or it works by default? And does installing SetCPU mess anything with your scripts? AND how do i uninstall apps i don't need?
Thanks in advance
Thanks in advancePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Thanks for the ROM Prahjister. Unfortunately I haven't been able to get it to boot yet on my MK808 to try it out. The initial boot sits at the floating globes splash screen with them dancing around for at least 60 minutes now. I will let it continue in hopes that it is just taking a very long time. The fact that the floating orbs are moving are a good sign to, I hope...
Anyone else experience an EXTREMELY slow first boot? How long did yours take to boot initially?Last edited by lordacid; 18 September 2014, 07:52.
Originally posted by lordacid View PostThanks for the ROM Prahjister. Unfortunately I haven't been able to get it to boot yet on my MK808 to try it out. The initial boot sits at the floating globes splash screen with them dancing around for at least 60 minutes now. I will let it continue in hopes that it is just taking a very long time. The fact that the floating orbs are moving are a good sign to, I hope...
Anyone else experience an EXTREMELY slow first boot? How long did yours take to boot initially?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I have had this ROM installed for a few weeks now and when it is working it works well but I find that sometimes there are a number of issues when I boot my original mk808b device like:
- It will have disabled wifi for some reason and I need to switch on again using the Android Settings
- It will take a long time to boot sometimes and other times it boots fine
- There are errors like Android System is taking a long time to boot and would you like to wait or kill etc. sometimes when you boot.
- Sometimes the wifi just drops and does not show any indication of this even though the router is right next to it and other times it stays connected fine?!?
Other little niggles here and there as well with performance and lagging on occasion...
Any ways to solve any of these as it would be a great little box if these issues were not there?
maybe cause
Originally posted by reni10 View PostI have had this ROM installed for a few weeks now and when it is working it works well but I find that sometimes there are a number of issues when I boot my original mk808b device like:
Either that or you have a bad flash.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 2494 users online. 0 members and 2494 guests.
