Minix Neo X8/X8-H Stock BETA 3 in flashable ZIP format
In my eyes it only means, that they do another way to 'fake' the temp at some devicesRK3288 Devices
- Overview BOX (LINK !)
Re: NEW - Minix Neo X8/X8-H Stock BETA 3 in flashable ZIP format
Originally posted by no_spam_for_me View PostIn my eyes it only means, that they do another way to 'fake' the temp at some devices
Originally posted by Batfink32 View PostTemperatures have changed in this ROM for me. I'm now down at 35-50 and around 40at idle. This is changed from 55-70.
my temps are at the top of the screen shot and it seems since the temps are reading different than beta 2, the throttling is not happening yet to me. i like this beta a lot more. havent done any bench's but the performance is better than 2. probably since the clocks are high.
Edit: been testing out the new beta and I experienced a couple random reboots. And some lockups. so naturally i thought it was me "overclocking?(actually the box says capable of 2ghz so this isn't really ocing)" to 1992. I flashed the CPU fix stock and uninstalled trickster and still I've had some lockups and random soft boots. This also is with xxposed uninstalled. I flashed fresh too. I'll get Catlog and see if I can catch it.Last edited by cuezaireekaa; 29 June 2014, 12:05.
Originally posted by cuezaireekaa View Postyes. my temps are way down and i was successful in setting max clock to 1992 instead of 1600 in TricksterMOD and it sticks. running bobs 1296 cpufix.
my temps are at the top of the screen shot and it seems since the temps are reading different than beta 002, the throttling is not happening yet to me. i like this beta a lot more. havent done any bench's but the performance is better than 002. probably since the clocks are high.
How can the box suddenly drop 20-30deg C? Doesn't seem right.
Originally posted by Batfink32 View PostBy flashing the CPU fix are you not just flashing the old kernel? Does the fix just not contain the altered kernel? This would be interesting as it would show the new kernel is not causing the lower temps but something in the ROM.
Edit: yes, kernel is dated June 28th so its updated.
Anyway, I'm having those shell restarts the poster above mentioned, even after another fresh flash. No tweaks involved yet.. It has happened to me after leaving the box idle for some time and then pressing anything will cause the soft boot
EDITED:: I've since turned off screensaver and daydream to see if that's the cause.. It happened from wake with those enabledLast edited by cuezaireekaa; 29 June 2014, 12:04.
Originally posted by cuezaireekaa View PostHe created new CPU fixes I thought in his new tweaked zip for beta 003.
Originally posted by Batfink32 View PostAhh OK, didn't realise there was new CPU fixes. A 20-30 deg drop in temp seems strange still. I wouldn't mind knowing what MINIX did to get this.
I don't thrust this figures, i checked temp with a ir temp reader and i have same number under load as i had with beta 2. Around 45c at reading the bottom off the box.
Originally posted by Gurra101 View PostCan't get 1080p 24 hz working with this! On beta 2 it worked just fine. I have reinstalled this 2 times but i just goes to a black screen and the back to 1080p 50hz.
Originally posted by reyito View PostCan´t install from Finless 1.0 rom
When mounting the device says "E: Footer is Wrong" and "E: Signature verification failed"
What am I doing wrong?
Thanks for your Help
Reginald
In his instructions, it clearly states in big red letters to unzip it and there is a read me. The ROM is inside the zip. Extract it.
Instructions are important if you're gonna be flashing
Originally posted by Trhuster View PostI don't thrust this figures, i checked temp with a ir temp reader and i have same number under load as i had with beta 2. Around 45c at reading the bottom off the box.
There are currently 4249 users online. 0 members and 4249 guests.
