Minix Neo X8/X8-H Stock BETA 3 in flashable ZIP format
Originally posted by cuezaireekaa View Post...not reading the op
In his instructions, it clearly states in big red letters to unzip it and there is a read me. The ROM is inside the zip. Extract it.
Instructions are important if you're gonna be flashing
Yeaahhh, it was my fault
That´s why I deleted the entry
Thanks for your help!!!!
Re: NEW - Minix Neo X8/X8-H Stock BETA 3 in flashable ZIP format
Originally posted by Trhuster View PostOk i did take it apart and measured both sides with my ir temp gun. I run 3dmark for about 30 min and then i got this readings.
Heatsink side: 48c
PCB side: 58c
Cpu temp app: 38c
FYI I can tell you the new sources from AML have changed the thermal throttling!!!!
So I expect what your all are seeing. Not saying it is right only that AML themselves changed it.
Originally posted by Finless View PostFYI I can tell you the new sources from AML have changed the thermal throttling!!!!
I'm hoping I understood Bob correctly.
Originally posted by cuezaireekaa View PostAha so that's the reason the clocks read lower.. So throttle doesn't kick in. Idk seems like its gonna overheat regardless, just when it overheats now, it will be with the clockspeed at a high freq instead of the throttled speeds (so it may happen sooner), so it may explain my random reboots. Its too hot. But the box is still very cool to the touch. I really just don't know anymore. Box is running good now save for the reboots.
There are currently 1981 users online. 2 members and 1979 guests.
