NEW - Beelink M8 & S82 / Tronsmart Vega S89 - wasser firmware 1.0.3
    version: 1.0.3
    - built from source based on 108K4
    - add wasser xbmc 1.3
    - add multiuser support
    - readd stock MediaBoxLauncher
    - update google apps
    download: http://www.freak-tab.de/wasser/wasse...link-1.0.3.zip
    version: 1.0.2
    - add for CPBLTV live stream
    - Decoding Dts/Dolby for S802
    - added suspend, Power-off, reboot, reboot into recoverver function
    - updated xbmc based on 13.1 gotham
    download: http://www.freak-tab.de/wasser/wasse...-s82-1.0.2.zip
    download: http://www.freak-tab.de/wasser/recovery.zip
    version: 1.0.1
    - built from source based on 106k4
    - enhance system stability
    - it can flash Ethernet MAC
    - enhance the power of 4k video decoding
    - fix issue of 1080i video playing
    - all google apps updated
    - 1080p24hz support
    - nfs, ntfs, cifs filesystem support
    - rooted
    - init.d support
    - added wasser launcher3, remove Google search
    - preloaded xbmc, youtube, skype, es file explorer, chrome
    - cleaned up UI
    - poweroff dialog
    download: http://www.freak-tab.de/wasser/wasse...-s82-1.0.1.zip
    version: 1.0.0
    - built from source
    - 1080p24hz support
    - rooted
    - init.d support
    - cleaned up UI
    - poweroff dialog
    download: http://www.freak-tab.de/wasser/wasse...-s82-1.0.0.zip
    HOW TO FLASH
    1. Download firmware wasser-firmware-s82-beelink-1.0.3.zip
    2. unzip wasser-firmware-s82-beelink-1.0.3.zip which contains factory_update_param.aml, recovery.img, wasser-1.0.3.zip
    3. Format a sdcard or usbstick to FAT32
    4. Put the 3 files on the root of the sdcard or usbstick
    5. Power off the device
    6. Insert the sdcard or usbstick
    7. Press the button in the AV hole, then press power button,then release button in the AV hole.
    big thanks to Oman for support/help/hardware
    Be aware: it is your own risk!
    Hi, could you post a/some launcher screenshots? And what's the base?
      Originally posted by wasser View Post
      version: 1.0.0
      - built from source
      - 1080p24hz support
      - rooted
      - init.d support
      - cleaned up UI
      - poweroff dialog
      HOW TO FLASH
      1. Download firmware zipfile
      2. DO NOT UNZIP, the zipfile is the update package
      4. Put the zip file on the root of the sdcard or usbstick
      You will see a menu:
      1. Select : apply update from EXT ( using your keyboard cursor )
      2. Select : Update from Sdcard / Update from udisk (usb stick)
      3. Select the zip file
      4. Press enter and wait until it is finished
      When it is done select reboot and press enter.
      nice work can we have screen shot -)
      Bugs are Sons of Glitches!
      JustMe
        Is your firmware suitable for Tronsmart Vega s89 standart. Can I flash your firmware to Tronsmart Vega s89 standart.
          Way to go Wasser!
          Finally another ROM maker shows up to the s802 party
            Way to go Wasser!
            JustMe
              FYI folks, this ROM's edify script is not erasing /data
              My suggestion to make sure things are clean is after flashing go into the recovery menu and do a "wipe data/factory reset".
              Well that is if your having any issues! Old junk left over could effect wassers ROM in some way so you might be reporting issues that are not the ROMs fault. So if you have some issue I would do a factory reset and try again just to be sure.
                A little feedback.
                ROM is working well so far. But like 105K4 sources, all the Google apps and GMScore/Play Store are outdated.
                Takes a little fiddling after first boot to get GMSCore and phonsky updated before it will update the other Google Apps.
                  A little feedback.
                  Didn't try but is it not possible to flash e.g. this:
                  Using it on my Nexus7 with CM.
                    Possibly but it's better to be in the ROM from the start since they are system APPs. An update like that adds the updates to /data instead of replacing them in /system. Just saves some space and mess
                      firmware.
                      Hello there, Iv just installed your firmware on my device & its verry good upgrade, but may i say that the power off app dose not work. It just restarts the device, Its the same thing with finless roms aswell. if you could fix this, it wood be grate. thank.
                        I always go with "Mini" and I believe nothing is added to /data .. but just to /system. When I update my CM it's always ROM->GAPPS->Kernel->SuperSU ... has never failed on me. And it cleans up before it pushes new files ;-)
                          it should work
                            Way to go Wasser!
                            the s802 Party begins now
                            wasser
                              wasser
                              Great news guys!
                              Thx Wasser for your rom.
                              Can't test now, but i m really happy to see a new kernel, a real one!
                              Did you compile a kernel from source? it really awesome
                              Regards,
