NEW - Beelink M8 & S82 / Tronsmart Vega S89 - wasser firmware 1.0.3
    Did you add the camera app? My Logitech C310 webcam worked earlier with the stock and finless's roms, but your 1.0.1 rom did not support it. Again, I am using a Tronsmart Vega S802-H
    camera app is included
      Thanks.
        When you edit build.prop you must make sure you have the same permissions on the file as the original had. If you copied out build.prop to a PC edited it and copied it back, permissions will be lost and you will see exactly what you saw on boot. If you don't understand permission my suggestion would be to use EF File explorer and edit build.prop on the device. This way does not change permissions.
        Thanks Bob. Here is what I've done:
        With EF File explorer, I have copy/paste the build.org from finless1.5.zip to the system directory of the box.
        At this step, in the system directory, I've build.org and build.prop.
        Then,I've rename the build.prop in builds10.prop and rename the build.org in build.prop.
        All of this with EF File explorer.
        With this procedure, I was sure to have no issue...
        I was wrong. Maybe a typing error in the name of the file or maybe the system don't like to have a file named builds10.prop...
        Bob, do you thing I can retry, or is there something to change ?
        CONFIGURATION:
        Hardware: TRONSMART VEGA S89
        Firmware: VISSONTECH 20140915 version
        XBMC: 13.2 (include in VISSONTECH ROM)
        Live TV addon: PVR IPTV Simple Client simple with a Playlist.m3u
          thanks for this release.
          but when i unpack this zip file its unpacking files he already has unpackt en over wrighting it with other files with the same name but with a bigger or smaller filesize.
          does this make sense LOL
          winrar is giving me warning to overwright or not ?
          thanks again
          for example : I:\system\media\audio\ringtones\Perseus.ogg
          I:\system\media\audio\ringtones\UrsaMinor.ogg
            thanks again
            I get the same warning + there is 7 files in the zip not 3
              this file comes down at 420mb not 441 and unrars to 640mb is this correct it tests fine before unrar but during unrar asks to overite several files mostly audio i think
                Could someone please compare stock 104k4 with wasser fw regarding video performance?
                I'm affraid to leave 104k4 because someone mentioned 104k4 as the best fw in this field...
                  thanks again
                  i forgot to add factory_update_param.aml, recovery.img. I even updated the flash howto and uploaded
                  the mssing files factory_update_param.aml, recovery.img
                  Please Take a look at the HOW TO FLASH in the first post again!
                  sorry!
                    update firmware flasht and gonna test now
                    thanks again
                      please take a look at the flash howro in the first post
                        Did a clean install and everything is working great so far, even the camera app works now. Still testing, will know more later.
                        thanks
                          sorry!
                          I like it, installed fine on my Beelink S83B v2.1 S802B AP6330 2GB/16.not had time full a proper test but looking good apart from still not being able to get ps3 controller to work I don't think any rom has this working yet on the amloic based devices.will test some more after sleep
                            it works now in 1.0.2 release. I have also added "reboot into recovery mode" so you don't need to press the button in the AV hole anymore when you want too flash firmware
                            wasser
                            I will try. It's beutiful news thanks very much for your work
                              Recovery zip in first post won't flash:
                              - footer is wrong
                              - signature verification failed
                              BTW .. what is it .. new version?
                                - footer is wrong
                                it sounds you haven't unzip the recovery.zip! I have updated the flash howto yesterday.
                                1. Download firmware wasser-firmware-beelink-s82-1.0.2.zip and recovery.zip
                                2 unzip recovery.zip which contains factory_update_param.aml, recovery.img
                                3. Format a sdcard or usbstick to FAT32
                                4. Put the 3 files (factory_update_param.aml, recovery.img,
                                wasser-firmware-beelink-s82-1.0.2.zip) on the root of the sdcard or usbstick
                                please give a try!
                                thanks
