Hi i need some help . I have an MX 3 , and i try to install the wasser firmware 1.0.3. After update completed i reboot the box and open the box with out picture. I shut it down and from that time my mx 3 wont turn on. I try with toothpick , but nothing happened. What can i do ? TIA
NEW - Beelink M8 & S82 / Tronsmart Vega S89 - wasser firmware 1.0.3
My MX 3 , won't turn on after install wasser firmware 1.0.3 - Please help
Originally posted by Nickdot View PostHi i need some help . I have an MX 3 , and i try to install the wasser firmware 1.0.3. After update completed i reboot the box and open the box with out picture. I shut it down and from that time my mx 3 wont turn on. I try with toothpick , but nothing happened. What can i do ? TIA
Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
You also tried one of these:
oman's one http://www.freaktab.com/showthread.p...-s802-platform
stane's one http://www.freaktab.com/showthread.p...c-M8-platforms
koying's one http://spmc.semperpax.com/
(BTW: SPMC can be installed parallel to XBMC)RK3288 Devices
- Overview BOX (LINK !)
tried this rom on the weekend, dunno if there was a glitch during install, but I couln't get the virtual keyboard to pop up durining initial setup ( wifi password ) tried opening keyboard settings and forcing asop, but no joy, had to roll back to stock 108k4...
Sent from my Commodore 64 using Geos
My devices:
Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
Remote control hotkeys
Hi guys,
Just tried this firmware on my Measy B4A device and it works great!
Thank you, wasser!
I have trouble finding a way to map the 4 colorful buttons on the IR remote control that came with it to some apps.
I used to find this setting under settings>languages and input>keyboard shortcuts,but it's not there anymore.
Any ideas?
Thanks in advance!
If I'm not wrong, it's at the kernel, so forget it... anyway, if not at the kernel, I think you can also forget itRK3288 Devices
Originally posted by no_spam_for_me View PostIf I'm not wrong, it's at the kernel, so forget it... anyway, if not at the kernel, I think you can also forget it
Could be linux
Originally posted by saor11 View PostThanks for the ROM wasser. Am using Vega s89 standard if I flash this ROM will I still have to use sound about app to stop hearing the sound thru my mele remote speaker.
How could i get a linux fimrware?
Hope some one could help me.
i have tronsmart s89h custom firmeware wasser v1.0.3 how i can back to original firmeware because i dont find button update in menu ty
Hope some one could help me.RK3288 Devices
or use app to reboot to recovery (http://www.freaktab.com/showthread.php?1050-Reboot-App)...
or use also a recovery.img at the SD...RK3288 Devices
There are currently 3238 users online. 0 members and 3238 guests.
