NEW - Beelink M8 & S82 / Tronsmart Vega S89 - wasser firmware 1.0.3
Originally posted by mattyspurs76 View PostHavnt had a reply so i went ahead with it anyway and low and behold.....its installed.
Got 3 launchers to choose from, Launcher 3, Mediabox and Wassers Xbmc so ill play around with them and ill let you guys know just how well this rom works with this box.
I've run this ROM for 3-4 weeks without issues. The only problem is the wifi/ethernet speed. It locks out at 10.3mb/s. Luckily I know my way around the firmware so I've made a new boot.img which unlocks the internet speed to 40+mb/s and also it unleashes the cpu_freq to its potential. (408mhz > 1992mhz)
It can be flashed from stock recovery on sd card. If you wanna try it let me know buddy.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
i would like to try this
Originally posted by ant View PostHey Matt! I personally wouldn't use the wasser xbmc launcher it will boot direct to xbmc. Just stick to launcher 3 or media box.
thanks for your time
Originally posted by mattyspurs76 View Postno problems with this rom at the moment. id like the files though. I use ethernet connection, not keen on wifi. ive eatched a film just with no buffering issues. everything seems fast and I find it better than stock and finless rom, but only been using it for about 8hrs
Try downloading internet speed test from playstore and test.
Flash my modified .img
Reboot
Test again
~RESULT!
Link to modified boot.img....enjoy
Flashing any files to YOUR device is done at YOUR own riskMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by ant View PostYeah the link wll be below.
It was affecting wifi and ethernet. Trust me....
Reboot
Test again
~RESULT!
Flashing any files to YOUR device is done at YOUR own riskPlease consider making a Donation to freakTab
Originally posted by mattyspurs76 View Postant, will this be like a fresh install and will I loose my stuff onmy box or is it just a fix and ive got nothing to worry aboutOriginally posted by blinkone View Postcan we just flash your boot image wthout losing our setup,& also what tools do we need to flash your image
We're only rebuilding the boot.img. No settings will be effected, promise.
All you do is put the file (DO NOT UNZIP) on your SDcard.
Boot to recovery
Apply update from EXT
Choose sd card
Then flash the wasser_bootimg_fix.zip
Reboot
You should now have good speed on Internet and the cpu frequency of 408mhz min clock > 1992mhz max clock.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Good rom Wasser
xbmc has issues with some files blank screen will try some other builds still looking for crisp video in xbmc and show box.
Awesome rom fast. I got am codex disabled and working great. Older xbmc notice maybe an update very at some point but crisp and clean. Installed the WiFi fix worked great. Add on working great. Weird issue if you install cpu fix before you install xbmc get a error installing hub wizard just noticed it and reproduced same affect. So install xbmc and add on before cpu WiFi fix weird one produces script error if you install cpu fix before xbmc? Having fun with this rom sappy and responsive. Well done.Last edited by scooter2014; 10 September 2014, 02:54.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostWeird issue if you install cpu fix before you install xbmc get a error installing hub wizard just noticed it and reproduced same affect. So install xbmc and add on before cpu WiFi fix weird one produces
Originally posted by scooter2014 View Postgetting a video sound off set in wasser xbmc? anyone else have same or fix?Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
There are currently 3128 users online. 0 members and 3128 guests.
