Could someone compare 104k4 with wasser 1.0.1 regarding this subject?
NEW - Beelink M8 & S82 / Tronsmart Vega S89 - wasser firmware 1.0.3
Originally posted by Finless View PostDid you try writing to a NTFS drive?
This was not possible in 105k4 but maybe they fixed it on 106K4?
I have not had time to test 106K4 yet especially since we know 107 is coming soon.
Originally posted by gnaw View PostJust flashed the 1.0.1 version with factory reset.
Everything seemed smooth except:
1) WIFI is broken
2) PLAY store only works occasionally
does anyone got the same problems?
wasser
Originally posted by daniello9 View PostI took the plunge and flashed this over finless 1.7. Everything ist like it was (which is good) but of course I haven't done thorough testing yet. My main reason was to test the CIFS implementation ...
Findings:
- Screen scaling had to be set again
- Busybox had to be reinstalled
- debloat with tibu
- reinstall Xposure
- CIFS: Mount manager app: Cannot access a needed shared library
- CIFS: busybox mount -t cifs //192.168.100.211/public /sdcard/etrayz -o unc=\\\\192.168.100.211\\public,username=i_wont,pa ssword=tell_u
fails with permission denied
i checked cifs again.it works fine for me I used this command line to mount video from my NAS
busybox mount -t cifs //192.168.2.20/video /sdcard/video -o username=test,password=test
it seems a problem on your Server!
wasser
Originally posted by wasser View Postwifi and play store works fine for me. it seems a problem on your wlan route. Please check
wasser
I was using Finless 1.7 without such issues. But now the WIFI disables itself after scanning networks a while. My S82 is connecting via Ethernet cable right now and the PLAY store doesn't seem to work as expected.
this firmware is made for Beelink s82. It looks like you have device with another wifi chip!
Originally posted by saor11 View PostIs CPU patch requiring
the default cpuinfo_max_freq: 1992000
the default cpuinfo_min_freq: 24000
Originally posted by wasser View Postplease try to reboot the device and check google play again.
My box has a AP6210 chip so would that be the compatibility problem?
PS. Just flashed back to Finless rom and the WIFI works fine.
I do hope to see a better and stable rom for S82 and I'm looking forward to see that happen =]
Cheers!
I installed your ROM and everything is working well. I chose to NOT to do a clean install just to see if it caused any problems, and it didn't. I just used the stock update tool.. I noticed that you did not include the update tool, I really like that tool since I swap a lot of ROMs. Also you did not include the stock browser, and that is my preferred browser. BTW, this is on my Tronsmart Vega S802-H.
Thanks for this ROM.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by wasser View Posti checked cifs again.it works fine for me I used this command line to mount video from my NAS
wasser
- I tried again with your slightly different syntax but still permission denied.
- I tried not to make the directory from adb shell as su but on the box via file manager
Still I have no permission to mount my share to /sdcard/etrayz
The directory shows as
Code:drwxrwx--- root sdcard_r
For the PS3 controller: in USB, it works perfectly. but in Bluetooth, like withe the finless patch, the pairing ask for a pin code. Then no connection.
Another thing for the next version: could you include the original build.prop with another name to have the choice in the compatibility of the play store ?
Yesterday, I tried to change it (with the original in a finless firmware), but after that, the box won't finish to reboot: the Wasser logo was yellow, in a bad resolution and turn indefinitely...
I Had to reflash it again with your firmware ...
I can't have my favorite apps because of the nexus 10 spoof...CONFIGURATION:
Hardware: TRONSMART VEGA S89
Firmware: VISSONTECH 20140915 version
XBMC: 13.2 (include in VISSONTECH ROM)
Live TV addon: PVR IPTV Simple Client simple with a Playlist.m3u
There are currently 2337 users online. 0 members and 2337 guests.
