NEW - Beelink M8 & S82 / Tronsmart Vega S89 - wasser firmware 1.0.3
Originally posted by typiak View PostFor the PS3 controller: in USB, it works perfectly. but in Bluetooth, like withe the finless patch, the pairing ask for a pin code. Then no connection.
Another thing for the next version: could you include the original build.prop with another name to have the choice in the compatibility of the play store ?
Yesterday, I tried to change it (with the original in a finless firmware), but after that, the box won't finish to reboot: the Wasser logo was yellow, in a bad resolution and turn indefinitely...
I Had to reflash it again with your firmware ...
I can't have my favorite apps because of the nexus 10 spoof...
Originally posted by florian83260 View PostThis rom works on tronsmart vega s89 ?
Originally posted by freeworld View Postshutdown work now?
wasser
Hang tight guys. I see Wasser is uploading now. Give it about 30-40 minutes and he should be done.
Originally posted by clarkss12 View PostThanks, it is downloading now. Will install it later.
thanks
edit. I think I downloaded too soon, the file size is 144,640 kb. The 1.0.1 zip file was 428,763 kb.
Downloaded it ... the File has only 274 MB, is it correct ?
Tim
P.S. Supergute Arbeit, Wasser, danke für das ROM
Originally posted by tim_freak View PostDownloaded it ... the File has only 274 MB, is it correct ?
Tim
P.S. Supergute Arbeit, Wasser, danke für das ROMMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Tim
Originally posted by wasser View Postit should be 441MB, please wait 10 minutes!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1885 users online. 1 members and 1884 guests.
