Perhaps the last JB Rom ever
So here is my new custom rom for xbmc media center usage on CX-919 AP6210 wifi TV-Stick. Kernel is based on latest Radxa source and has new HDMI driver and real Rec. 709 color support (16-235).
It's a really freaking fast 1080p full JB Rom and plays 8 GB MKV 1080p files over SMB/UPnP wifi inside my mod of Flumpters Beyond XBMC absolutely smooth with dolby/dts passthrough (haven´t tested bigger files cause i haven´t any).
Features
- HDMI Output with real REC.709 16-235 color support!
- pureXbmc with dolby/dts passthrough
- 720/1080 24P/25P support with
1920x1080 at 60, 50, 30, 25, 24 Hz
1280x720 at 60, 50, 30, 25, 24 Hz
720x576 at 50 Hz
720x480 at 60 Hz
640x480 at 60 Hz
Kernel doubles the framerate at 24/25Hz if your Monitor supports.
24/25 will be displayed at 48/50. No sluggish mouse movement anymore at 24p!
Best viewing experience in XBMC with 60/50 Hz.
- Kernel has HDMI-CEC support
- Working Bluetooth and Wifi
- rom is rooted and should support init.d scripts.
- Kernel supports a lot of file systems, like ISO, UDF, NTFS, FAT32, HFS, NFS...
- modded launcher with Auto hide system bar option, performance settings, terminal and app background image
- 2GB, 4GB, 6GB parameter files
Very cool Total Commander file explorer, Reboot (thanks to Petrus), Terminal, YouTube, SuperSu and pureXbmc (mod of Flumpsters Beyond XBMC Beta 3.4, THANKS!).
Thanks to Radxa, Bob, d33, Flumpster, Wasser, Petrus, Lewy, phjanderson, MINIX and all the cool people at Freaktab.com!!Thanks to mo123 for the info about Radxa sources. Thanks to Christian Ghisler for Total Commander
pureXbmc V2.1 CX-919 1080p JB 4.2.2 Rom
(Download link does not contain any kernel, please download kernel separately from links below)
Kernel V7 for CX919:
kernel_cx919_1080p_v7_walter77_cpu1608_ddr696_gpu6 00h_vsync.zip
Additional kernels V7 with different ram speeds and voltages:
kernel_cx919_1080p_v7_walter77_vsync_cpu1608_gpu60 0h_ddr400-ddr696.zip
Use it at your own risk!
